Hi everyone,
If anyone wonders how to create plasma, just read Aaron's book it's all in there. I can confirm it works 100%!
I got new diodes and new wire and it works with the new wire and new diode. However, it works perfectly with the old diode string I made in the first place too.
I think I had the plasma earlier, but I just didn't see it as I was expecting a huge golf ball size of plasma. The 5520 feeding my Pro Power coil can't produce a golf ball size. MSD claims the Pro Power is too big for the 5520 and not compatible with that CDI box as the Pro Power coil requires too much power. Anyway, when I attach the string and remove it, I can clearly see the difference before and after. I recommend anyone to have the spark tester as outlined in the book that gives continuous sparks instead of grounding "by hand". It's so much easier to spot the difference when the system runs continuously. If you have cash and don't want to build the circuit in the book, you can buy a spark tester from MSD which sets you back a few hundred bucks... I'm sure that if I would have used a coil that was really compatible with the 5520, the plasma kernel would probably be bigger.. I'm still very happy as i could reproduce the phenomenon!
The spark looks as if it's about 2-5 times bigger (subjectively) than the original CDI spark.
All in all, it WORKS!!
Yiha!
