A few newbie questions.
  • I connected the LED under the scheme: Click image for larger version
ID:	45209 My device works in a mode repulsion. This means that the red LED lights up when placing a magnet on top of core? Magnet should be exactly in the center of the core, or have small tolerances?
    Konstantin.
    • sorry to interupt can someone please tell me repulsion and attraction mode..my superpole light LED exactly after pass the centre..i cant get in the between magnet like John K youtube on timing. even on my sweetspot..TIA
      cheers,
      Alfin
      • Originally posted by kingstingtin View Post
        I connected the LED under the scheme: [ATTACH=CONFIG]1377[/ATTACH] My device works in a mode repulsion. This means that the red LED lights up when placing a magnet on top of core? Magnet should be exactly in the center of the core, or have small tolerances?
        Konstantin,
        I'm not sure about which colour LED lights up when, I only use one LED and swap the connections to see either the coil on time or off time as needed. I'll check mine tonight and let you know.
        • Originally posted by alfinip2000 View Post
          cheers,
          Alfin
          Hi Alfin,
          I recommend you read through this thread which talks about attraction and repulsion modes Complete Bedini SG Book!
          • Originally posted by John_Koorn View Post
            Konstantin,
            Thank you, John. I'll be waiting for your answer. I too did not connect the two LEDs at once. I soldered here such thing: Click image for larger version
ID:	45213Click image for larger version
ID:	45214Click image for larger version
            Konstantin.
            • Hello again everyone!
              I completed 20 cycles of charge / discharge my new battery.
              Please see my table. SSG COP CSB En.zip
              Seems to me that I was not the right result.
              I still continue to train on the battery, hoping that the situation will improve.
              Konstantin.
              • - Doctor, me all ignore.
                - Next!
                Konstantin.
                • Konstantin, I don't think there is anything wrong with your load testing results. What were you expecting?
                  • John, I expected that the capacity of the battery will not be reduced. And while, the COP battery is greater than 1. But while it turns out one or the other. Or not worth it expect such results from this device?
                    Konstantin.
                    • Have passed 24 cycles. I managed to yet slightly increase the resistance on the basis of the transistor. From 187 to 189 ohms. I'm not sure, but it seemed to me that the device has to consume a little less current (320mA instead of 330mA). And the wheel was rotating faster. From 238 rpm to 240. Could this be the result of changes in the battery?
                      Konstantin.
                      • Konstantin,
                        that is normal for the device. You should continue to adjust the base resistor until the rotor no longer increases in speed. When the machine is tuned properly you should be able to charge the secondary before the primary goes flat.
                        • Thank you for your reply, John. Later, I found not a pleasant thing (which I do not understand) - current flows in the secondary battery is also increased. And, more markedly, from 95 mA to 110 mA. I think that a negative impact on the battery COP. Or is this normal? My thoughts start to get confused again...
                          Konstantin.
                          • Konstantin,
                            I never worry about the current into the charge battery, just that the machine is tuned properly. I would continue your load testing and see what difference the change in base resistance has made.
                            • Thank you, John. I have great respect for your patience, and I can imagine how you find it hard to explain simple things such ignorant people like me. I'm just trying to stick to the system, but the constantly changing conditions, and I do not know what to do. It knocks me out of the way. I will continue to train the battery. And I will follow the changes. Maybe I'll buy another battery to power the device. Although I am not sure that this will change the situation significantly.
                              Konstantin.
                              • Keeps surprising me the device. At the completion of the next charging current flows into the secondary battery is 90 mA. How could this happen, I really do not understand ... On Monday, I will buy this one: батарея аккумуляторная 3Cott 12V 18Ah купить в москве санкт петербурге спб Юлмарт. I count using it to power the device. Maybe I'll see therein a returning part of energy.
                                Konstantin.
