Konstantin.
You are using wrong discharge load for your battery(GP 1272 12V 7.2Ah) in your table you have 370 mA , but for 20 Hour discharge you should use 360 mA
All of charge and discharge cycles should be done in C20 rate, which means 20 hours for charging and 20 hours for discharge .
Your last charge cycle was 31 hours and discharge only 9 hours.
My advise: try following, adjust your system to 160 mA power draw from primary battery, this info is actually was given by Bedini himself.
Than charge battery for 20 Hours, if you didn't notice any voltage increase after charging battery, than it's something wrong with your curcuit or with battery which you using for charging.
PM if you need this information in Russian language.
There are still nine cycles. After I saw how has grown battery capacity when charging it lasted until 16.18 V, I really want to do it again.
