Originally posted by kingstingtin
every wheel is different, every machine is different, you will NOT find a standard speed, your speed depends upon current draw, core material, batteyr size, everything makes a difference. I will tell you if EVERYTHING in your wheel is the same except the core of your coil, then what do you think needs to be changed? put the welding rods in your spool, get the laminations out of your core its acting like a solid piece of iron.
