Potentiometer and a resistor soldered in series. I understand the way with washer. And what size washers should be?
I experimented with a gap and resistance. And I realized that my opinion about the strength of the magnets was a mistake. I realized that I needed a light 9V 0.019A for proper startup device. Because the device must run at resistance of 300 ohms. And if I do then it gradually increases to 800 ohms, the device dials the maximum speed and reduce the consumption of electric current. But if I try to immediately run the device in 800 Ohm resistor, it will not enter the desired mode.
P.S. kingstingtin = Konstantin (wordplay)
