Originally posted by heysoundude
The diodes go from the coil + connected to the cap + in the msd/cdi units straight to the top of the spark plug. That bypasses the cables so actually you can use stock high resistance cables that might be 5.5k ohms of resistance since the cap in the plug bypasses that and goes straight over the spark on the plug.
However, the advantage with lower or no resistance cables is there will be a much stronger initiating spark created by the hv output of the ignition coil. It is still a CDI/MSD spark and is already stronger than 12v input ignition coil spark, but so much of it gets dissipated by the resistance of the cables. Might as well get what you pay for and go as low of resistance as possible without causing computer interference. On old carb cars, Granatellis are probably best.
The stock plugs are typically around 5.5k ohms as well just like the cables so normally that is around 11k ohms, which is a lot. The secondary in typical black body canister ignition coils are around 10.5k ohms so not sure if that is intentional where they are matching the resistance.
In summary:
1. 0 ohm plugs or close to that as possible are necessary so as not to resist the discharge of the cap across it no matter what kind of situation.
2. Use as low of resistance cables as possible so as not to interfere with on board computers, etc. At minimum, performance cables intended for CDI/MSD ignitions on computer cars is preferrable and on non computer cars, Granatelli is probably best.
Leave a comment:
