Originally posted by Richard
The first results with the modified NGK are:
#1 2.8% reduction in fuel consumption.
#2 misfiring at high revs.
Leave a comment:
Hi,Originally posted by Hellenic Vanagon View PostThe problem is within the mobile's camera structure, which cannot record smoothly, as if something, (radiation?), disturbs operation. The flow of the events, in reality, is uninterrupted without missing a bit. Using headphones you can hear that the rhythm of the discharges follows a normal pattern even at the points we cannot see the discharges.
Yes, you could be true...the camera cannot capture what an eye can..after all it an assisted viewing
A similar thing happens when you record using a camera about the brightness of LED or the color of the neon bulb. for LED The camera presents it to be brighter than what it actually is!!
it is vital for me to tell just by the color of the neon-bulbs in SSG/SG if its Positive Radiant or Negative Radiant. camera viewing cannot capture this intricate detail.
In your video of the Spark-discharge, there are intermittent jumps if I may so call it.
This is inherent to modern day camera in terms of interference as you rightly pointed out. or sometimes is the result due to Stroboscopic dephasing effect.
rgds,
Faraday88.Last edited by Faraday88; 06-04-2018, 02:05 AM.
Leave a comment:
The unexpected result, using the modified NGK BUE, is that it seems giving plasma even having the power of the plasma unit off, (not that strong though).
You can see the phenomenon at the first moments of the next video, (here the same cell phone works a little bit better.):
The ignition system must be stressed a lot know and I am ready to resolve problems.
The modified NGK BUE (MKII)
Leave a comment:
Thank you very much. I 'll try.Originally posted by RichardSee if you can get a Samsung S9+ cellphone to try out. They have a 720 fps slow motion camera mode.
Richard Gieser
Leave a comment:
The problem is within the mobile's camera structure, which cannot record smoothly, as if something, (radiation?), disturbs operation. The flow of the events, in reality, is uninterrupted without missing a bit. Using headphones you can hear that the rhythm of the discharges follows a normal pattern even at the points we cannot see the discharges.Originally posted by Faraday88 View PostHi,
Looks like the discharges are a periodical for some reason...this can happen if you have parallel paths (like several spark plugs in parallel)
Leave a comment:
WeaponX had some iridium and rhodium non-resistor plugs I came across a couple years ago - have not had time to test them out, but that would be the next plug I'd test. http://www.weaponxperformance.com
Leave a comment:
Hi,Originally posted by Hellenic Vanagon View PostIn such unprecedented applications, usually, the good results may be affected by enthusiasm and happiness so it is better to remain calm for the next day's real results.
Leave a comment:
Leave a comment:
This is the new MKII NGK BUE, (experimental):
You can see the two parallel discharges, (f. ex. at 0:36), and the new stronger arc.
My phone camera is interfered by the radiation and records image intermittently when the sound is recorded normally.Last edited by Hellenic Vanagon; 06-03-2018, 06:47 AM.
Leave a comment:
what you are referring to is a continuous rating (360Amps) and is characteristic to Arc- discharge Plasma and not Spark-discharge plasma the difference is but obvious. The peak current in the Pulsed plasma, of course, can go to several hundred Amps. Aaron's Plasma does the benefit of an Arc-Plasma in a Spark-discharge for a given power input. btw Ignition Energy is non-thermal at inception like a spark-plasma.Originally posted by RichardMy TIG welder is rated 360 amps and that is through a 1/8" tungsten electrode, far beyond the amperage/conductivity requirements of an ignition system.
For Plasma Arc systems satisfactory conductivity isn't nearly so difficult to achieve (especially when you are talking about 2" of conductor length) as is acceptable life expectancy at which copper and it's alloys lags tungsten by a considerable margin.
The outstanding feature of tungsten, for Plasma applications, is it's high-temperature durability during arcing.
As implied by my original question, has a TIG tungsten electrode been tried for comparison purposes for both spark performance and durability?
Richard Gieser
rgds,
Faraday88.Last edited by Faraday88; 06-02-2018, 11:32 AM.
Leave a comment:
Hi Richard,Originally posted by RichardThanks Aaron.
Yes, I reviewed that article recently and the comment "Thermocouple Alloy made from Tungsten - Rhenium Alloy which can withstand temperatures of over 2500 deg C and can be
used here but it's pretty difficult to find in retail." is what inspired me to make my comment about the easy to purchase TIG electrodes. Also, thermocouple wire is usually very thin.
I'm guessing that you have done some TIG welding yourself. I can't think of anywhere that gets more severe arcing than that tungsten tip.
For the (2% thorium) tungsten rod there hasn't been much change in the welding industry for about 50 years to my knowledge.
I would think tungsten rods would be first choice for a plasma spark plug conversion. Isn't it also the material that incandescent light bulb filaments are made of?
That guy went to a LOT of work to make his sparkplugs in the article.
Richard Gieser
Tungsten used in TIG welding is for preferential melting of the base mental surface. However as you rightly pointed out it is used in the incandescent bulb for reason that it has high resistivity otherwise you cannot have I2R loss and thereby produce White hot light.
However, in Pulsed Plasma spark application you would need highly conductive electrodes that have good shock resistance.... i cannot think of anything other than solid-copper...
Leave a comment:
Superb Aaron!!Originally posted by Aaron Murakami View PostPlease look over this doc carefully: http://www.hho4free.com/spark%20plug...lasmaplugs.pdf
Robert krupa's plug and your patent came much later....how did Robert excite his Plasma??
I know yours is true Plasma ignition is terms of modest power input.
the plug and the Power to excite it are two different things..
your comments please..
Best Regards,
Leave a comment:
Please look over this doc carefully: http://www.hho4free.com/spark%20plug...lasmaplugs.pdfOriginally posted by RichardTIG welding uses a tungsten electrode which can be purchased for $30 for 10 pieces (makes 20 sparkplugs?) of 1/8" diameter by 7" long.
Have you heard of anyone trying this material for the center electrode in the sparkplug?
Leave a comment:
I'll have to look at my old pics to see if I see them at the same time. Of course it is only possible for the cap to discharge after the HV normal spark jumps, but could be so fast the high current impulse from the cap jumps the gap before the spark is extinguished. That supports my belief in the accelerated discharge.Originally posted by Hellenic Vanagon View Post#1 The distributor is bypassed for the plasma, which is driven directly on the spark plugs, with tv cables.
#2 No, I haven't the equipment necessary to make them.
#3 I will try to catch the double discharges and I will post them.
Theoretically speaking, is it possible to have those two discharges in parallel, having between them a tiny distance, or they must coincide absolutely, as at 95% of the events happens ?
Leave a comment:
Leave a comment:
