At $299 a set for my 8 cylinder I don't think it can work for me.
At hvstuff.com I can get; 30kV 330pF High Voltage Ceramic Disc Capacitor $0.79 each
But if money is no object then it looks like an easy way to go, maybe.
Likely need to experiment.
Richard Gieser
Off subject some but in anyone’s opinion there’s a company by the name Nology that makes spark plug wires the they claim can increase spark output from a capitor in the wire. From my understanding it’s a wire mesh sleeve that goes over the inner wire that causes resistance and ups the spark. They claim in can increase spark by 300%. Could this work, I know it’s a far cry from a plasma ignition but just asking. Thanks
Leave a comment:
I don't recall the efie settings - I think I built it with an LED driver ship based on plans from George Wiseman.Originally posted by rokan View PostI'm curious Aaron what kind of magnets were you using, how were they configured on the fuel line, what strength were they and what kind of additive did you use? Because I have tried all of those things and never got any gains that were worth speaking of?? I was also using an EFIE circuit, do you remember your circuit voltage settings for the offset the EFIE was putting in the computer?
Ron
Fuel additive was RPX Gas Kicker: https://www.amazon.com/gp/product/B0...SIN=B0002JN6H8 I used to be a distributor years ago. It decarbonizes the engine, reduces temp, almost completely eliminates nox on diesels, etc. many benefits proven in many dot tests.
This is the exact magnets I used: http://www.magnetizerproducts.com/products.php#autogas - that is my website. Polarity is opposite between fuel and air, you can see the red blue. I don't recall which is which.
Leave a comment:
Have you hooked up the unit to your car and ran it with just the basic MSD ignition?Originally posted by rokan View PostHi Aaron,
I now have my Street Fire unit and am ready to do the final hookup!
If you can fill me in on the rest of the hookup pointers I will greatly appreciate it!
Happy 4th of july!
Ron
Leave a comment:
Connecting my MSD?
Hello Aaron,Originally posted by Aaron Murakami View PostWhen you hook up the MSD/CDI, you are already getting a stronger spark at each plug - from coil, thru distributor directly to each plug.
After the MSD/CDI is hooked up, then you add diodes. 4 of them.
If you're coil isn't suitable for capacitive discharge, I'd recommend this one: https://www.amazon.com/gp/product/B0...SIN=B002Q363XM
After getting the cdi/msd hooked up, post your results and then we can diagram the diodes to the top of the plugs. That will be super easy.
Since I only have the stock 96 Tacoma distributor, do you have an idea of how to connect my MSD unit to the magnetic pickup? Would I disconnect all the original wires coming from the magnetic pickup inside the distributor and connect the MSD to it as if it were an MSD distributor? Will that work? Does it get any signal from the computer that I will be interrupting?
Ron
Leave a comment:
It seems that, finally, I found a way to post BIG images...
Leave a comment:
From my documents collection:
Here is the reduction in the voltage can be done by a resistor, (R stamp), sparkplug:
11313 volts, (with a 4960 Ω, conventional, resistor), vs 23.31(=nothing) volts!Last edited by Hellenic Vanagon; 07-07-2018, 06:39 AM.
Leave a comment:
Another point: retarding the timing, as it is supposed with plasma, there is a sharp increase in consumption, according to the trip computer measurements. It has to be as close as possible to the pinging point for the less possible consumption.
Leave a comment:
Yes, Both Parallel and Series Capacitor or both simultaneously (like i said in a Natural Lightning Discharge) can infuse Unpredictable power surges that can undoubtedly damage your scale of design in the coil/Switching etc..! question is.. how do you it at will ???Originally posted by Hellenic Vanagon View PostIn my case a capacitor in parallel is forbidden by the manufacturer, ("do not connect capacitor of any kind to the primary"), but there is no prediction about a second, parallel, coil.
when you use kittering coil application its Parallel capacitor with Parallel Resonance (connected continuously across the primary), while in CDI/Plasma it is Switched Capacitor with Series Resonance. The Manufacturers of coils say that for this reason..i feel.
Its my sincere urge to all to experiment with Parallel and Series Resonant High-Voltage Coil see what you end up with..! Look how the nature does it even with out a 'coil' understand it. what the hell in a Lightning Discharge is playing the role of a Coil??? Triboelectricity(Frictional Electrostatics) is just not it!! ponder on these lines and you may end up with the holy grail of Tesla's Secret to Free Energy!!
Faraday88.Last edited by Faraday88; 07-06-2018, 11:36 PM.
Leave a comment:
A bit clairvoyant as well!Originally posted by Hellenic Vanagon View PostTesla is smiling.
T.v. antenna unlike
any other https://drive.google.com/file/d/1y9M...ew?usp=sharing
floating valves not giving feedback https://drive.google.com/file/d/1ogq...ew?usp=sharing
to each other.
No missing signals
from the air
no blurred signals
on the air.
Tesla is smiling. (From there).
Bips and bums
and burning lights
smokes and thunders
and delights,
currents, voltages
through air,
sparks and arcs
but no despair.
Yesterday a burning light
flawlessly hovering in night
a message carrying to the site:
"Tesla is smiling" (From height).
The Syncro HeresyOzone smell and clairvoyance bear synchronicity!
compare Electrolytic Ozone (produced at high-Current density) and that produced by High-Voltage Silent Electric Discharge(corona-discharge)
@ Aaron your expert comments please...
Best Regards,
Faraday88.Last edited by Faraday88; 07-06-2018, 11:33 PM.
Leave a comment:
In my case a capacitor in parallel is forbidden by the manufacturer, ("do not connect capacitor of any kind to the primary"), but there is no prediction about a second, parallel, coil.Originally posted by heysoundude View PostIndeed, Voltage and current are inversely proportional.
That second link, explaining dwell, is wonderful. Thank you!
It seems that a capacitor in parallel to (across) the ignition primary is an excellent idea in any application; sizing it correctly is the issue.
Leave a comment:
Originally posted by Faraday88 View Postenjoy smelling Ozone a littel of this gas is mood rejuvenating i must say
Tesla is smiling.
T.v. antenna unlike
to each other.
No missing signals
from the air
no blurred signals
on the air.
Bips and bums
and burning lights
smokes and thunders
and delights,
currents, voltages
through air,
sparks and arcs
but no despair.
flawlessly hovering at night
The Syncro HeresyLast edited by Hellenic Vanagon; 07-07-2018, 12:06 AM.
Leave a comment:
Indeed, Voltage and current are inversely proportional.Originally posted by Hellenic Vanagon View PostNow I know: 6A-7A current are, in fact, used by the primary, (although, at the secondary, the amperage is at mA):
LINK: http://dtec.net.au/Ignition%20Coil%2...alibration.htm
Now does any one know what can happen, (to the ECU), connecting two ignition coils in, (primary & secondary), parallel, feeding them by the same triggering module, which is designed just for one coil?
In the above, excellent, linked, article it is mentioned: " Primary voltage usually lies in the 300- 400V range and is electronically ‘clamped’ in most systems to prevent the switching device being damaged".
So it seems that, usually, there is an overloading protection.
But there are so many other aspects, f.ex.,
#1 using two coils, are they operating cooler, important factor to their sensitive resistance vs temperature?
#2 is their rising coefficient improved by halving(?) their operational stress?
At least, this is claimed by the next article excerpt about the Jag's system:
#3 is it better the auxiliary/main configuration or, if they are matched, at least, it is better to discharge through separate, parallel, paths?
Leave a comment:
Yes!! The Primary discharge capacitor is charged to 300-400V form a pre-step up high-frequency coil. as i said in the previous post, parallel primaries is the way to go if you are looking at boosting the power level in the out put(i mean power) wonder why the coil manufacturers do not have this provision(or do they??) since even with CDI its the Capacitor discharge Ignition (Series-Resonant) and this has been the standard for ateast over a decade and half i must say! the same is not true in the kittering coil mode(Fly-back)..current limitation due to the core saturation is a problem in this case, in the later case even if the core is saturated the out put does not get affected due to the nature of series resonant action.Originally posted by Hellenic Vanagon View PostNow I know: 6A-7A current are, in fact, used by the primary, (although, at the secondary, the amperage is at mA):
Just a thought why not make custom coils our own??? well if you do you shall learn hell lot of hidden stuffs!!( lots of insulation and dielectric breakovers!!! though)
Faraday88.Last edited by Faraday88; 07-06-2018, 04:34 AM.
Leave a comment:
#3 is it better the auxiliary/main configuration or, if they are matched, at least, it is better to discharge through separate, parallel, paths?Last edited by Hellenic Vanagon; 07-06-2018, 01:55 AM.
Leave a comment:
Leave a comment:
