Four Wave Mixing
  • John_Koorn
    Vtech, sounds like you have a pretty good setup going there A bit more professional than my el-cheapo method
    I don't suppose you want to send me some Canadian coins In Australia you'd be extremely lucky to find a 1966 round 50c piece which is silver (worth ~$16), or pre-decimals
  • blackchisel97
    Vtech, those will work fine but the sticky stuff will wear out quick. I use brass discs, about 1" diameter that I cut out of some brass sheet I had laying around and then just sticky tape them to the "test subject". I just wet them (spit works well) before applying them.
    Thanks for a tip John. I bought several sets for my Beck units and we have been using same set for the last 6 months. It is always good practice to wipe skin with alcohol to remove grease and any residue. We also use conductive gel. This greatly extends the life of gel pads. Even when they don't adhere well anymore you can use gel and medical grade adhesive dressing tape. For wrist application you can cut off elastic upper part of a small sock and it will make a wrist band, similar to the "fancy" one used by tennis players.
    Also, Canadian Maple Leaf coins are 9999 silver.
    Vtech
  • John_Koorn
  • blackchisel97
    Originally posted by pir View Post
    I use carbon fiber or platinum gel pads, such as these - OrthoCanada. Pals Platinum Electrodes
    Vtech
  • pir
    silver electrodes constructed
    Bedini's & Bearden's 4 wave mixing from 1987 update5 - YouTube
  • blackchisel97
    as long as it is a carbon pile battery you are good. those old school lantern batteries work well. ray o vac 6V lantern battery. Tom C
    Thanks Tom, that makes perfect sense, two of them in series...
    Vtech
  • Tom C
    as long as it is a carbon pile nbattery you are good. those old school lantern batteries work well. ray o vac 6V lantern battery. Tom C
  • blackchisel97
    Originally posted by slloyd View Post
    lol, wife & i are feeling EXACTLY the same way!
    about your setup - on john's schematic you see on the right side 'Dry Cell Only'. this is very important, are you using that? the machine will impart the electromagnetic makeup of whatever is the source (here a Dry Cell battery) through the silver electrodes and into the "test object".. so .. ya, you want a dry cell because of the solid electrolyte. i guess then it becomes very important the make & manufacturer of that battery .. so, if you apply the electrodes to "test object" and are not finding good effects i would say change the battery to different manufacturer.
    i wonder which dry cell battery manufacturer JB used?
    according to bearden's notes, just turn the machine on, apply to "test object" for 45 minutes to 1 hour and repeat once a week. have you tried this?
    Well, I much prefer being waken up by the birds than morning traffic
    My understanding is that neither liquid electrolyte battery or mains should be used but only the battery with paste/immobilized electrolyte. Not to confuse with dry acid battery which you fill with distilled water after bringing home. Also, I wouldn't use this device for a period longer than 20min at the time, same as Beck Brain Tuner. I tried last night but can't really tell if it did anything to me or not since I don't have any medical conditions that I'm aware of. Contrary to MWO which makes me feel like an "Energizer Bunny" after 15 min session. I live in relatively healthy environment (not counting occasional chemtrails in the sky), can walk bare-feet on the dew moisten grass and smell flowers instead of exhaust fumes. Cannibalized TV and microwave several years ago, threw out cell phones, disconnected phone line and wireless router. The price which comes with that is that I can't find any decent job for the past 1.5 years but I'm still alive. Very alive
    Vtech
    They just opened up and I can smell them in my kitchen -
Name:	Pink Peony.jpg
ID:	45709Click image for larger version
Name:	Crimson Peony.jpg
  • slloyd
    Originally posted by blackchisel97 View Post
    I love the Upper part and smell of forest. Closer to GTA.....I couldn't live there. I grew up in the city of 1.5mln and lived in Montreal for 8 yrs. Now, 2000 heads village is too crowded for my comfort.
    Last edited by slloyd; 07-06-2013, 08:30 PM. Reason: not medical doctor did not want to give medical ideas.. so changed to "test object"
  • blackchisel97
    It makes sense....I didn't think of that. Just mere concept of single 555 drawing >50mA didn't smell good to me.
    I like your idea with a tree. They like different forms of electricity and can supply some as well.
    In 1964, the USDA performed tests in which a negative electrode was placed high in a tree, and the positive electrode was connected to a nail driven into the base of the tree. Stimulation with 60 volts DC substantially increased leaf density on electrified branches after a month. Within a year, foliage increased 300% on those branches.
    Vtech
  • pir
    ....I changed them later to 1kOhm and everything ran cool...
    aha !!! got you there....!!!
    did you know that with a low value helps the 555 to get a 20ns~60ns rise time...? I DIDn't !!!
    that is why i say it is not a "simple 555"...
    a month ago if someone came and told me that he can get 50ns rise-fall with 555 i could hit him to the head with an analoge scope of 50kgr....
  • blackchisel97
    actually the freq from the first updates are wrong.....the correct are: 50,150,300, 1,5K ,7K ,and the last for my *case is 15K
    * "my case" means that to get 25ns rise-fall with 50% Duty can't go up more , i screw up the 25ns and the perfect 50%
    if you go and put 50 Ohms or 150 Ohms ....or the other values from shem you get overheat and you lose the freq lock
    on a bredboard i put the values from the schem on a test 555 setup and on the first 1sec before overheat and freq lock lost i got the rest unknown
    then i use above 270 Ohms all over on the final setup poted with epoxy as a heat shink and as a temp coefficient , also the "control circuit" is a voltage stabilazer
    it is something wrong with the scheme over the 555 resistors bias...maybe then (1987) the 555 could be stable with those values....and today's 555 are different
    my test "subject" is a plant as shown on video and it is getting better all ready...we'll see , notice that the machine can easily produce over 50μA on a 1.2m distance of live wood
    chears
    Ok, thanks for clarifications, so the frequencies are the same as I have, except 350Hz instead of 300Hz and 10kHz on the 6th instead of 15kHz. 50Ohms is wrong value in my opinion. I worked with 555 when they first came out on the market and don't recall such low bias being used. I found 150Ohm an absolute minimum to get them stable but this is still very low. I changed them later to 1kOhm and everything ran cool. My last version was done on HFC4047 which hold perfect 50%dc and are more stable than 555. Again, this is my opinion only. Still not sure how to test this. Hopefully, when the kit becomes available more details should surface.
    Until then, I continue my work on MWO which seems to be superior to any medical device I've ever built before.
    Thanks pir
    Vtech
  • pir
    Nice work pir. How did you come up with 453 and 700Hz frequencies? The first three were on the diagram but the other two were unknown. I have sixth oscillator set on 10kHz.
    Thanks for sharing
    Vtech
    chears
  • blackchisel97
    Thanks for sharing
    Vtech
  • pir
    my replication on YT series:
    "Bedini's & Bearden's 4 wave mixing from 1987" series
    (till now update4)
    my channel :
    i made 3 boards till now , the 1st is a ptototype , the 2nd was a fail, the 3rd is the final unit
    i have studied the circuit wery well , i made many improvments also and i think i got it to 100% as is in John's paper (waveforms)
    i manage to get ~25ns rise and fall times from ne555 with low L proto-PCB 2-layers , you can't get that with cmos 555 or CD-seies logic chips as John said
    i use 2SC3552 and the base is driven with extra circuit to get better fall time (about 1.5~2.2us with load)
    actually allthought may be a simple "555 circuit"...it's not!!!
    build one for you ... let me know if you need more details about my replication
    p.s. many thanks to John
