Here is a picture to get your attention!
Thought I would link some photos of a coil I wound today. Labor day morning…took me around 1 hour. It took longer to take the pictures than it did to do the work. It is a four lead power coil using #18 cu wire and #19 cu trigger. The four leads were laid out, twisted, and then wound onto the same spool we use for the ssg. The electronics were already packaged on a previous coil construction experiment using #18 aluminum wires. Many pictures are attached so you nubies can get a feel for the work involved and construction methods used. Thanks to Marcia Stockton for the twisting idea and lawn chairs!
I also had previously wound a 7 lead coil #26 and #30 trigger for an experiment. It worked OK but I was after something much more powerful. I replaced this coil with a 7 lead winding and transplanted it into an existing electronics package I had from before. It too was wound using #18 cu and #19 trigger. 8 leads total! When I first fired this coil up it did not work as planned. Not all of the transistors fired at the same time because none of the electronics were matched. I later found out that it worked Ok @19 volts input. All 7 showed firing with the scope during charging. Note the spool size difference….I knew it would not fit the ssg spool so used a speaker wire spool I had laying around. It has a 1” dia core!
Some of the specs from the entire unit running with all three coils is as follows: 19 volts @ 6.7 amp from a 20 volt power supply....Center coil on the ssg is #26 power and #30 trigger just like the previous forum specs and outputs .6 amp @ 19 volts......quad filar coil is #18 power and #19 trigger - outputs 1.8 amp @ 19 volts input......The 7 lead coil is #18 power and #19 trigger - outputs 3 amp. The total output of the system is 5.4 amps. Wheel speed is 197 RPM. Here are some pics of the whole assembly running.
Lets me say that this is the same bike wheel I started with....just a little modified on the magnet spacing. Also none of the electronic componenets are matched! I did this just to see what would happen. At 19 volts the scope showed that all the transistors were firing though. This very crude assembly is charging these monster batteries no problem. This is the breakthrough I have been looking for since joining this forum. I just needed to know what the limitations are. There are none…. Just your imagination! Next stop one hell of a big generator. Just need to do the engineering drawings and construction. Oh I won’t forget the electronics matching!
Pic of my night light! I remember using the alum for chancre sores when I was little.
I hope these pictures help you guys out a little. I joined this group last year during the Christmas season. The biggest education I have is from all the dvd’s from John and Tom. Without them all this stuff on the forums does not mean much to me. In my opinion the dvd’s are pricesless! Also one of the best working educations is from the 50+ runs I did to prove to myself that COP>1 is achievable using that tiny SSG coil we all start with. I did one hell of a lot of practicing and experimenting using different stuff john talks about on those dvd’s….paying attention to what is said and not said. John is not going to give you anything….you must earn it. While I was at the conference I was sitting with one of John’s employees having a beer and she was complaining about how john would make her do things she did not want to do. I told her as a boss I would have done the same thing. If John does the work for you…..you will never get it….but if you stumble upon it the hard way then it is burn into your memory for all time. This is how you learn for real……by the failures! Not the successes. Read, listen, understand…..and god sakes do something!
Bud
Bud
