Yes it works. You can switch it using a quad pole, double throw switch (break before make is very important), or wire it manually one way, and then the other. The output is not AC (so forget about the caps), obviously but you will end up with fairly close to 12 v DC. My expiments with that showed the recieving batteries went to 15-16 volts in very short order, at which point they're not accepting any more charge, and you're wasting energy. And I didn't really feel like sitting there flipping a switch every few seconds, plus I think a normal switch would probably wear out fairly quickly due to arcing.
All I did was get 4 batteries and a bunch of alligator clip wires, and put a lightbulb as the load, no rectifier (light bulb don't care which way the current flows), and wired it up manually, stuck a current meter in between different points, measured potential. Knock yourself out.
