Water Spark To Hydrogen And Water Vapor Pressure Ran Engines 2005-2008
  • #46
    the several statements made by Nathren and Nathren's son Nathren, is that all earlier CONVERTED car engines were readjusted for timing to A T D C to about negative 34 degrees , as that approximate point allowed the engines to run smoother and provided water vapor pressure as a secondary force on piston, as generated at the lower end of piston travel. On the 18HP mower engine , the 13 turns wire over steel core section WITH the cable, as electromagnet provided magnetic field on the high volts cable and caused the spark time to be extended in milliseconds. He said to add more or less turns , so as to get the best setting for running engine. My own improvement design over his S1R9A9M9 coils assembly was to make the adjustment variable by varying amount of core under #14 wire + cable, as a pull handle. (Like turning loosened distributor on car engine) Hydrogen gas used in standard engine requires way late timing . I also increased the number of turns as per ratio change required, when changing from original 10 A current to 6 A current, to maintain the same magnetic field level. . Car engines are 4 cycle as well as the Briggs engine, but it has waste spark cycle that does no harm to a running engine.
    Each engine will run slightly different and a blanket statement cannot be made, as they all will require adjustment in different timing points. Nathren had made statement as to the available special degrees flywheel keys as used for different timing on Briggs engines. They all , however, are only for the small Briggs animal racing engine flywheels. I don't think he knew that. The Georgia technicians did not modify Briggs factory timing, other than adding magnetic field. I just assumed they were too lazy to machine a curved aluminum , slotted, mounting plate for Magnetron, as for being adjustable timing thereafter with screws and nuts repositioning.
    I am presently testing my latest S1R coils as 10kv cable included, rather than bare wire or insulated hook up wire, or 30Kv cable, so as for getting a constant recurring 100v leakage transfer without shorting. The wooden flywheel arrangement with Briggs ignition works well with series inductor coil and diodes. Later, I will blend in DC current to spark plug with water solution and protective diodes section. The water solution presents ohms resistance and would raise up the input voltage required, as also tiny electrodes.
    One of the original web forum paragraphs by Nathren , said in broken words, that there were other parts than the S1R coils in the plastic tub on side of mower engine!!!!!!! This was when he and son stopped saying anything more their set up as too much attention was received, and non-knowledgeable people had gotten hurt trying to duplicate his engine set up.
    When the man, "Smack ", showed up, at his property after 1000 miles driving, the episode was on video tape and we could see what was going on. The wiring on failed running 18HP was not done the same as during the 2 successful You tube videos of 2008.
    The Nathren back porch engine test was wrong also, as he was attempting to run engine with S1R coil as in induction type mode,- not with current output going direct to spark plug as needed. In one of the published answers to people's questions, way back in time, he said the output 12v current wire WAS CONNECTED to spark plug . (not repeated again)
    • #47
      2008 S1R9A9M9 Georgia Water Engine
      I have some more tech data for you to consume. See also sheet Inverter output described by A I.
      I finally figured out why the green 400watt Inverter was not used. It was used OK on all previous car engines. Statement said it bogged down and quit as the attempt on operating Briggs 18HP. The You tube videos showed unit in background only, unconnected with clips on ground. It was placed there to mislead public. The engine started and ran in both videos. Previous MULTI CYLINDERS engines had used majority of wattage from 400W Inverter. The one cylinder mower engine required less watts power. The tech people used the brand power on board for 750W and 400W inverters. A MUCH SMALLER SIZE INVERTER FOR 110V AC WAS PURCHASED JUST FOR THE VIDEOS. The way "small" box fits in rear hole of cement block during the demonstrations. The 400W box does not!! The engine vertical shaft is in same hole rotating with great clearance from box. (box 3.3" X 3.3"300Watts) (They could of put the larger Inverter box in depression at ground level with cement block on top.) The demonstrations were keeping people from knowing all. Parts were not exposed. Parts were purposely kept in sealed plastic tub and also spray painted to keep eyes out. The Inverter pre made, allows the required 100 volts , due to the tiny electrodes of spark plug. The 10 amps initially came from car battery, then once engine running idle, battery removed, then the double alternators took over to run the conversion circuit.
      Dual alternators with just full wave rectification , without voltage regulator, provides higher volts and about 14.5 amps output capability.
      Here goes-- The positive battery cable clip touches starter terminal to run starter motor. Separate wire is also there going behind engine through diode. The input to inverter in cement hole, attaches to cathode side of diode. The diode prevents alternator from running starter. The alternator DC runs Inverter also, when battery removed.
      The S1R9A9M9 electromagnet provided magnetic field over ignition cable ( bare copper section) to form late timing from zero to about minus 34 degrees. The amps came from battery, then alternator DC at idle speed. Resistor in tub to limit current for S1R coils. The plastic tub connections needed for ground came from the exterior extension cord that was modified for extra long single wire to ground , and jumping the male end plug.
      The S1R coils is 100% on all the time to keep magnetic field at spark plug in-between firings. The power pulses to spark plug is on + off about 34% for ON duty cycle. (Flywheel going around 360 degrees)
      Plastic covered tub on side of Briggs engine contains S1r coils electromagnet, resistor, bridge rectifier for dual alternators, bridge rectifier for Inverter output, wire connectors, accessory spark gap, and wire joint putting output amps together with high volts going to modified zero ohms Champion spark plug.
      All previous car engines had 2 spark gaps in main circuit. The distributor rotor firing gap and spark plug gap. It helps to insure the plug fires rather than misfire.
      Mineral water was used for running mower engine with salt added that came from creek on the Georgia property.
      The dangerous ignition high voltage was on car battery only during the starting mode. (No series diodes protection bank)
      I was stalled, hung up , for long time on the 100volts source, power current means, difference between peak and average current, and higher high ignition volts.
      I found it greatly interesting to use the old style large clip clip board with mechanical pencil/eraser, printer blank paper, to form diagrams and notes over long period of time . I have many titled folders on different subjects related to the S1r project. (half cup of coffee helps)
      I will later be working on separate circuit to remove the waste spark cycle of Briggs engine. one and zero up counter IC and reset using Hall Effect sensor.
      Your comments will be appreciated.
      • #48
        It's my current assumption that the conversion circuit of S1R9A9M9 2008 lawn mower water engine 18HP on You tube videos, had used a hidden "small dimension size" Inverter box, about 300-500watts , that was INSIDE the rear hole of cement block with engine on top . Plenty of clearance also for the vertical rotating crankshaft. The other parts were hidden in sealed, painted plastic tub , hanging on side of engine. we could see. Therefore, the Inverter power source was hidden also, so as after the battery was completely disconnected, the engine conversion circuit ran off of the alternator installed under the flywheel. The Briggs stator of yellow+ yellow wires is capable of 20amps dc current. The ignition only operates during about 34% of flywheel turning, so as the wattage from Inverter box is reduced by 34% also. So as current delivered in DC pulses was 6-7-10 amps DC., The hidden Inverter box was being operated in the upper region called "SURGE current" which these boxes are capable of. The pure sine wave type output boxes give much higher surge currents, than the modified sine wave type which is square wave pulses waveform on an oscilloscope. Remember the significance of the very low duty cycle. So now you know. The 400watt green Inverter shown in videos,was not used-, not hooked up, not because it couldn't run the engine, but because it was too big to hide in cement block. The conversion circuit required about 100 volts and current same time. The other S1R9A9M9 electromagnet provided the magnetic field to change the timing to extend to negative late timing, and also provide required field for the tips of spark plug. The high voltage cable hooked to the heavy current same time as going to the zero ohms spark plug. Hydrogen gas evolved and fired along with generation of water vapor pressure.
        7amps X 110v = 770watts times .34 duty cycle flywheel usage, = 260 watts or less drawn power , plus the electromagnet current . Both draws are capable of the on board changed alternator. The black+ black wires Briggs alternator is the exact same low ohms as the yellow yellow. Just get the cheapest one. The 500W pure sine wave Inverter is about $40 called LVYUAN painted blue color. from US EBay shipping. Outer size 3.75" wide by 7.8" depth - IT FITS very loose in cement block, or 300W red LVYUAN 3 1/4" by 3 1/4" size.
        • #49
          There are options when selecting a replacement ignition coil (Magnetron) for the mower engine. I was interested in changing over to positive high voltage rather than normal negative high voltage. There are a couple reasons. When tinkering with small engine for alternate uses/ fuels, There are high voltage shocks received when connecting parts such as resistor, capacitor, L coil, to engine ground. The spark plug refuses to fire, and bypasses to go up another line such as parts. During that time we get shocks from the engine. Also, when using the original old style Magneto as just a plain transformer before 1982, you can put it upside down on engine bracket and get positive high volts, but at away reduced level. You don't get up to 15kv anymore. The Autotransformers normally have the primary coil hooked directly with secondary side. The full secondary is normally primary + secondary in a negative "mode" Less wire is used in the positive mode.
          Now then, there actually is a better way to get positive type high voltage at FULL VALUE VOLTS! If your Briggs engine is a one cylinder type, you can purchase a modern replacement Magnetron with DOUBLE CABLES. The secondary side is not connected with primary. When used on the twin cylinder engines, each spark plug gets different type power. Negative on one side and positive on other cylinder. Also, if you get the most modern type dual cables Magnetron, it will have the better type built in UNIVERSAL type trigger , rather than the Briggs brand trigger. Engine will fire at a lower RPM of flywheel , just like in the "olden days". Just hook the negative cable to ground and the positive cable to spark plug. Compare the photos of armature Magnetrons on Ebay to see the difference.
          • #50
            2008 Mower engine ran on salt water.
            Closing in on the final conversion electrical circuit as used during the successful demonstrations 18HP Briggs on YouTube. The hand wired S1R9A9M9 electromagnet on 10amps provided magnetic field to spark plug gap and OVER the plug wire to readjust the engine timing to late timing ATDC. The duty cycle of on time was for the current pulse through spark plug of needed 7amps PEAK.
            There was a separate Inverter box of about 300watts that provided the current at 110v DC to fire plug. Use was about only 150 watts, due to the low duty cycle. Average value of current on hand meter would be about 2 amps, for the 10amps peak. The box was hidden in rear hole of cement block with engine shaft. (plenty of clearance.) Other parts hidden in sealed plastic tub on side of engine.
            The car battery operated starter motor and also the electrical conversion circuit. Battery removed. The modified Briggs alternator with flywheel with the larger type magnets would provide max 20amps as divided between the electromagnet and inverter box primary side. Engine then ran fully on alternator permanent magnets at idle RPM . Can use black + black wires stator or yellow + yellow stator as are both Exact same construction. Hydrogen gas evolved and fired with also water vapor pressure that runs the piston. See S1R9A9M9 videos 1 + 2. Questions?
            • #51
              I'm changing my methodology of hook up to my 12HP mower engine. Instead of designing for full 20A alternator output to run the conversion circuit, I am changing over to bench "power source"
              to run main circuit with the under the wooded bench engine vertical shaft for car 52A alternator , belts and pulley, to recharge 12v mower battery. This method fully allows no shorting-
              electrical problem of Inverter box ground and battery ground. This is what hindered many people before, and I want a better chance of instant running of water engine when 1st started.
              Project has taken too long.
              Return line to Inverter hooks to wire and spring steel retainer clip on bottom of spark plug , just like from Georgia engines converted. One ohm power resistor in line for use with
              oscilloscope to monitor and adjust current flow.The way to do this is with smaller Briggs engine that has flywheel with ALUMINUM ring gear. The matching starter motor will have PLASTIC
              16tooth small gear. Starter is mounted with 2 black nylon plastic 8MM bolts 12mmm long with 2 plastic nylon washers. This insulates starter from engine block fully, when Inverter is
              activated. Slight distance change inbetween the 2 gears. Ground cable attaches to starter housing.
              Method is had by changing old armature Magnetron to the most modern Magnetron with dual cables, modern universal built in trigger , not Briggs type, so that Magnetron is NOT an
              autotransformer. (Separate secondary side) The ignition process is self contained without using BATTERY ground, as power is from one magnet on outside of flywheel.
              Main power source is PURE SINE WAVE ONLY Inverter similar to Lvyuan 500W Blue box with MORE available SURGE currents, to get 7amp pulses through spark plug. The most common modified sine
              wave type boxes do not give much higher surge current. Bridge rectifier and filter capacitor gives proper DC output.
              What I'm talking about is the instants when the battery ground is normally at bottom of spark plug, and Inverter power jumps gap and connects with ground within the 0 to 34 degrees ignition
              ON TIME, and repeated. This is also why a common boost converter or regular bench power supply can't be used. Inverter only with separate secondary side, they come in high frequency and
              also 60 cycles.The 2008 2 videos had the dangerous negative high voltage on the car battery during the starting mode.
              The S1R9A9M9 electromagnet allows high volts to go straight through without problem with the 12vDC line. I use 10KV white china cable to stop all shorts along with #16 gauge solid insulated
              wire for the 12 + 23 turns, with adjustable pull core for magnetic field inside vinyl tube center. The series adjustable power resistor allows change in input 6A battery current for the
              field adjustment. This will change the pulse on time of high voltage so as more contact time of Inverter current with the water solution.
              Photo included today is gadget for testing firing of hydrogen by popping off end PCV cap as press fit. Baking soda/water solution put on plug terminals . The outer ground lug is cut off for
              wide gap, and allowing blast to go straight out. Stainless steel marine spark plug is sealed in with epoxy at one end. Ignition white cable return line is screwed to plug base through
              plastic shell.
              • #52
                I put together another handmade S1R9A9M9 electromagnet for use with Four amps current. My last other one was for 6 amps with different windings. The now current one is exactly like the original as per unusual winding method and like Megatran, with same original count of turns. Red white and blue just like our flag. It has variable inductance with pull core. Another one of my improvements. Nathren said a set up needed about 15 amps total. That would include the "smaller" Inverter input 11 Amps + 4 Amps electromagnet. Ohms law step up transformer voltage ratio 1:10 as same as increase of input side power current. This was assuming the dual alternators type was not changed on his 18HP Briggs. He told me directly that his engine DIDN"T HAVE AN ALTERNATOR! All riding lawnmower engines have an alternator. He said he bought it new just for the 2008 videos to make. I saw lots of grime, dirt/dust on it in close up photos from years of use. The dual alternators type with red + black wires with bridge rectifier added to both sides produces about 15 volts DC at about 15 amps max capability. PEAK current on bench oscilloscope set circuit as 7 amps, with proper resistance in series, with AVERAGE current over full cycle time as about 1.3amps at low duty cycle. See photo electromagnet.
                Later today, I also mounted a new starter motor on project Briggs 12HP engine. It was electrically insulated from engine block with plastic bolts and plastic washers. The battery ground cable mounted onto starter only. Separate needed connections will go on 2 mounted brass bus strips for plus and minus of battery wires power as needed. The Inverter box secondary side firing to spark plug will never burn out as shorted to battery through spark plug ground, as per many other people's previous disasters. The flywheel has proper MATCHING aluminum ring gear, along with proper MATCHING PLASTIC starter motor small gear. Plastic gear during contact cannot make any electrical connection. Verified with ohmmeter. I'm always pushing forward.
                I am also putting together P.W.M. so as can vary the output of Inverter final DC and KEEPING PEAK VOLTAGE THE SAME, while varying the current , wattage, and duty cycle on time. The 100 volts is necessary for the tiny electrodes of zero ohms spark plug. I didn't want to get into capacitor discharges , since they go in the realm of microseconds, not required milliseconds of spark plug.
                Sometime I will rewrite my poor drawings schematic diagram and send copy, so as you can see my judgments for final circuit. It includes many diodes and 2 Dayton brand modified Inductors for 1.75millihenries. I also have for later tests, the 2 vacuum chambers hand made of magnets, spark gap, diodes and inductors.
                • #53
                  Waste Spark Removal Briggs Mower Engine For Hydrogen Conversions
                  I completed building the circuit for eliminating waste spark. It's the plug in bread board type, not soldered. It's easier to make adjustments later. Two photos for you today-- did not go through. I have handful of different magnet Hall sensors to try out and see which one should be used on engine with NORTH pole. Some of them are industrial with cables. Three wire type as +Vcc , grnd, and signal out. Most Halls are used for South pole reception. You have to bend over the Hall for the rear side use, or reverse, and mount with bracket. I will use hand movable magnet north pole only for first tests. Then to switch over to my revolving wooden bench flywheel with magnet , Magnetron, and spark plug. First yellow Led is first state (Fire) , the red Led is 2nd state with relay switch on that shorts ignition to ground BEFORE magnet reaches T.D.C. Then next passing point is reset back to first state fire. The other guy on Youtube who built his soldered type circuit years ago has my same name Russell. His board is similar to mine - not copied. I designed it myself. Plastic board put in miniature vise with strong lamp and use needle nose pliers. With 9v battery use, I design small circuits with 2 ma type, .002A led's. Most Led's are 20ma .020A. The battery lasts longer, but those are expensive and are special order. You just change the resistors. Of course, 2 batteries can be put in parallel for more time. Yes, I'm still working on the S1R9A9M9 system. 'Questions?
                  • #54
                    Proof That Nathren's Briggs Engine Had Dual Alternators!!!
                    You Tube Smack investigates claims of S1R9A9M9 time 6:03 ENLARGE PHOTO
                    Briggs 18HP has alternator cable hangs down behind starter motor and oiling tube. See cable against metal casting, see white 2 piece wire connector, and 2 wires there.
                    Long time back I directly asked Nathren about engine serial number to get capabilities such as alternator. He flatly denied that it had alternator under flywheel. He even said there were no magnets under flywheel. He started protecting his + shop technicians invention.
                    • #55
                      Update Briggs Engine Ran On water In Carb 2008
                      More data has unfolded showing that the 2 successful demonstrations of 18HP mower engine of 2008, had been using bottled water drawn into carb in a "vacuum" condition of engine intake , as being made more volatile to external media. The increased ignition volts to 24kv was applied to spark plug that has magnetism present from electromagnet. The impressed magnetic field of S1R9A9M9 triple wire coils on plug wire forms a required late ATDC timing of Briggs engine. There is a time delay again because of opposite reversed flows of power through the coils. Positive low v 13 turns to negative ground for electromagnet at the tap, and the connected 7 turns hooks to TOP OF PLUG, (Ground when fired) and positive ground ignition jumps upwards. The negative ignition has electrons going into the water mist changes to molecules of negative ions that repel each other and form pressure to push piston , along with small amount of Hydrogen at spark plug that fires also. The main energy came from the beginning car battery that was completely removed after start mode. The on board dual alternators provided either 10amps AC or 15 amps full DC for use , so as engine self running. The 300watt Inverter was not used.
                      Mentioned also from old documents was resonance between the water cell of spark plug water capacitance with inductor coil as resonant frequency equal to the input frequency of ring alternators. 3uf across alternators would make them equal. There are 12 permanent magnets to run alternators under the flywheel going around .
                      There was a university lab test done years ago that proved the notion of ionized expansion of water vapor to pressure. It also works with discharge of high v capacitor into water with resistor RC time constant. It has to be in milliseconds, not microseconds. The test chart showed that at certain resistance in series the BLAST outward was more than the input power and verified.
                      • #56
                        Most people don't take the time to read all messages on subject. They don't like long paragraphs. There were 2 demonstrations back in 2008 regarding mower engine running at idle speed on salt water. The battery supplied amps for start only. The idle RPM dual alternators supplied up to15 amps for conversion circuit. Alternators + ignition self running by 12 +1 magnets and crankshaft rotation. . The Ignition coil on a Briggs engine is called a Magnetron (with SS trigger). The S1R coils assembly does 3 things. Am ample increase in high voltage, extension of timing from TDC to -34 degrees ATDC, and applying mild magnetism to spark plug electrodes. The added Inverter box supplies additional power 120v AC to DC , about 10Amps Peak pulse Amps to spark plug. This circuit was used by the tech people on all the earlier car engines tested . Those used also a special relay per cylinder. The S1R coils replaces the unabtainable obsolete 60 cycles traffic signals control relays. Approx 4A to electromagnet coils over plug wire, and 11 amps to primary side of Inverter, for 15 A Max 12-14v DC from alternators full wave DC. The mower circuit also used an inductor of 1.75millihenry , and extra required spark gap. The plastic housing had room for 1 relay . There was talk about the relay diode joint with high volts entrance point forming Radiant Energy that may have increased conversion efficiency. The Vacuum sealed relay stops loss of RF in ambiant air. The salt water and 120v DC at plug forms hydrogen gas and fires same time. (spark plug electrolysis) There was also water vapor pressure contributing to the piston compression. There are several US Patents on same thing, going way back in time. Low engine power output but usable, as for instance operating an electrical 120v AC power generator. The tech people said a higher HP engine required by ratio to add a generator requiring certain HP. Ohm's laws still in effect.
                        • #57
                          Proper Car Engine Power For S1R9A9M9 Conversion
                          This message is in regards to the Georgia conversions on the earlier 4,6, 8-cylinder engines , 2005-2008) used with mineral water. The shop had worked on a hundred adjustments for years , trying to get it right. They talked about surging, rough engines, and some actual improvement came when it was Nathren (father) who was the only one who noticed about EGR being used on the better running engines.
                          I had made up a list of possibilities of minor changes that I had never submitted to them, possibly they never thought of.
                          I wanted to tell you about one of those on the list. The Georgia techs used the same Inverter box on each car with the matching relays per cylinder, to make use of the inductors and diodes. Now,....... There are several types of Inverters 110v AC output. (I prefer the 220v units as diodes bank loses about 10 volts)
                          There is the low frequency 60 cycles as modified corrected sine wave (square waves).
                          The 500W 20khz high frequency open board China Inverters with multiple outputs.
                          The 500-600W 60 cycles pure sine wave circuit Inverter unit.
                          The 1000W Blue box Tataliken brand 12v to 220v from China direct Aliexpress $27.92 on sale. Pure sine wave.
                          The specs sheet is important. See also not saying 250W continuous power 500W peak. Read the fine print. You want the 500W as general use continuous. This is so you can get a higher amps value as peak. (Average amps used is low)
                          Why this is important is because Inverters also give a specification for Peak, temporary current under 40% duty cycle. Such as 400W to 800W with an associated peak amps pulse current. The cheaper quality Inverters are mostly modified/corrected sine wave. What that means is, not quality repeatable same peak current in fast pulses. It is now assumed that the Georgia techs needed to change their input power to Pure Sine Wave , more costly Inverters. It has to do with type of electrical load as resistive, inductive, etc. They had never , over the years finally corrected the engine running problem. Also, source to purchase exact special relays never found. They had been using the Green Inverter box Power On Board 400watts, modified sine wave, 12vDC to 110v AC.
                          • #58
                            The shop in Georgia had converted several cars , as 4,6,8 cylinder engines on mineral water. They all had standard alternators. The one most talked about was the 1978 Chevy ElCamino V8 running on mineral water. There was a separate 2nd battery used to run the Inverter box . The alternator charged both batteries with diode isolation box. For off idle power, the main jet in carb is re drilled about 33% larger. The car reported to get 18MPG water, but after later reusing some of the waste exhaust drippings, the mileage went way higher , due to the addition of Nitrogen embedded in the expelled water. Smother running engine also. The other v8 on engine stand was running electrical power generator 24 hours always on. The regular alternator recharged battery, and the GENERATOR provided free electricity for work shop. Data taken from the now shut down web forum. Spark plug electrolysis for hydrogen gas + water vapor pressure.
                            • #59
                              The DC generator is mounted under flywheel of all Briggs riding lawn mowers engines. On the S1R9A9M9 engine of 2008, it had what what called DUAL ALTERNATORS. The red and black wire is actually (2) separate AC alternators output. The opposite ends of the coils are grounded under the plastic ring under the flywheel. Black is AC power, not a ground wire. The 2 AC wires extend to rectification to recharge battery or provide power to extra circuit. It is UNUSUAL to use the 2 wires at same time for same purpose, instead of headlights + charging line. The flywheel contains 13 permanent magnets. 12 for the generator and 1 for the ignition. No input is used to run generator or ignition other than turning crankshaft. When hydrogen gas fuel is made at spark plug , the engine starts running. The battery was used for the starter motor only, then completely shut off. Power to make electrolysis is then coming from generator at idle speed. Salt water is allowed to flow into top of carb from hose + bottle. Diodes needed to get DC to make low efficiency electrolysis of water. Fuel gas forms at tips of spark plug and fires same time. The added wire coil changes the timing ,as is needed with hydrogen. The spark plug receives what is called pulse PEAK DC current as about 10A. Spark plug was changed to Champion QC12YC at 125 ohms , rather than original 4000ohms resistance. They also come apart to remove resistor to get a Zero ohms racing plug. ( copper #12 wire segment replacement)
                              You can verify an old used engine would just run by adding 70% alcohol, or acetylene gas from carbide stones + water added, or also Ether spray into carb. The sound of Nathren's water engine on hydrogen from 2008 sounds like a water pump. Youtube (2 )videos by S1R9A9M9​
