The SG Radiant Oscillator
  • solarwindodua
    Hello John b. I have been able to charge 12V 60 amp hours to 15.23 volts. But the next charging is not allowed to do the same. More than 14.4 volts, not rising. If you continue to charge on the battery voltage decreases. What did I do wrong? I can not yet grasp the essence. Perhaps it should be, in the lifetime of the battery internal resistance and impedance too. Correct me! Sorry for my English.
  • Faraday88
    i guess this is a variant(embodiment) of the Google patent 'Circuits and related methods for charging a Battery'
    it cannot be for sale..
    i hope i'm right John?
  • solarwindodua
    Hi I'm from Ukraine. I want to ask on the way I? Works well only for low voltage. Is this correct? If you can tweak me John B
  • drpingol
    Good day sir !from Cebu,Philippines I was amaze I try to replicate your SG the wheel does not move ,but it still produces radiant energy using two dead battery, it continue oscillating almost 3 week and used to charge the distilled water and it 190 mil volts
    I also try to grow Cristal seed using your video.....God blessing be with you always....
  • Prinsloo
    Wei
    can you give us more detail of your system, please, what are you charging, from what, the usual specs please.
    Maybe a photo or 2.
    Theunis
  • Wei
    Originally posted by Mostie View Post
    no heat, mine only switches on for milliseconds.
    The switch is controlled by a picaxe and it turns on for 50milliseconds. I am pulsing the 27000uF cap at 30v.
  • Mostie
  • Wei
    Want to ask about the temperature of the IRFP260 mosfet on the cap pulser, do they get hot? Mine is going up quite high and I need to put a big heat sink on it.
    I also tried the darlington pair using MJL21194 & MJL21193, and that occasionally latches.
  • Jeffrey Joseph
    Thank you John,
    The branch is as you say. You are the man.
    Truth,Justice and the value of the individual.
    Happiness and Joy from my front porch is Hilo,Hawaii.
    Jeff Joseph
  • Lester
    Greetings to you John B. from the Philippines =)
    John B. I sent you pm.
  • GlenWV
    Greetings all:
    I built a single transistor unit per JB's drawing as a 'proof of concept' and it worked good. The waveform was like JB's and it was charging a lawn tractor sized battery.
    Next, I built a six transistor version using one MJ15024G and five MJ15024s. Power strands for each transistor were two paralleled #30 gauge wires, 40 feet in length, and litzed. The trigger wire was also #30, but is closer ot 90 feet in length. Each transistor and coil is a separate unit mounted on perf board. (It occurred to me that all the wires could have been litzed and bundled together. Another duhhhh moment!!)
    The base buss is a closed loop, while the collector and emitter buss' are open - like a multi-strand SSG.
    The setup raised a lawn tractor battery from 12 VDC to over 15.5 VDC in just a few moments. Power is from five paralleled 45 watt solar panels resting comfortably on a shady hillside in West Virginia. (That means the sun just aint too hot -- or bright!)
    Next, I connected the unit to a 12VDC 3000AH bank. It raised the voltage reading from the 11.8 VDC area to the 12.15 VDC area pretty quick. I left it connected there for a few days and it rasied the voltage to the 12.25 area.
    Then, after stumbling onto/into my large SG transistor board and smoking 117 base resistors, I connected the thing to all four battery banks - paralleled. (10k AH total of pretty crummy batteries.)
    Even with our nasty weather, the Radiant Oscillator is keeping the battery voltage in the 12.15 VDC area. (I feel a Newark order and a larger version coming on.....)
    @All: I have a few (3, or 4) 48 Volt LaMarche chagers sitting around that were saved from dumpsters. Most were working when removed from service. These are free for the asking and go to whoever asks for as long as they last. They are heavy, figure 70 lbs packed, so consider the cost for shipping. If you want to make the trip to Charleston, WV, you can pick one up and go through my junk pile.
    It would be best to PM, or email me in order to not clutter up the thread.
    glen
  • vallentin
    You're welcome.
  • Faraday88
    Hi Vallentine,
    Thanks for the information, i have extensively read ''Explanation of John Bedini's Formation of Negative Resistors in Batteries By Tom Bearden 4-26-00' and the Bedini website and have couple of his DVDs as well.
    what i was amazed to see is the wave form on the scope due to an Electrochemical contact e.m.f from the alum cell with spikes in it, which does not happen in an ordinary cell.
    i will explore this some time after my present work on the Monopole energiser.
    Thanks again.
  • vallentin
    Hi, Faraday
    Yes, there is. If you look at the movies on Energenx channel you'll notice that Mr. Bedini circuits go negative. Because are designed to. Tesla solar switch and the comparator circuit for example.
    Look at the way those analog meters swing around and how much energy is captured (in Joules) during the process. Do the math.
    I suggest you to use Mozilla Firefox, install this add-on: "Download YouTube Videos as MP4", restart Mozilla, download every movie at max resolution and watch carefully. You'll learn more than you ever think.
    Also, search youtube for any conference you can find. Like this channel: kishbud
    Please read this: Explanation of John Bedini's Formation of Negative Resistors in Batteries By Tom Bearden 4-26-00
    Or better yet, read everything you find there: The Energy Pages. Follow the links...
    I promise you won't regret.
    Regards,
    Valentin
  • Faraday88
    Hi Vallentin,
    Thanks for your extended info. i have'nt worked much on the crystal battaries as yet,
    just help me on : is there active spike in that Zinc- alum Cell shown in the video, that is very interesting!!!!
    Negative Resistance Device?????
    please help me catch up...
    rgds,
