John Bedini's Magnetic Model
Hi Dave,Originally posted by Dave Wing View PostI thought I would repost this diagram that was found in a video made by Davy Oneness, it is a pictorial tribute to John’s work that is combined within an interview with Dr. Bob Hieronimus. The original image was not very clear...this one is much better.
Here is the video link: https://youtu.be/skv4uOwxjzs
It was a reminiscence of those beautiful 'years of revelation' between 2004 -2008 when I worked extensively on the Bearden-Bedini-Peter models. So dearly I miss him. His explanation of the theory was unparalleled. one really needs to blessed to bear Synchronicity and have him as a Guru in this Field.
we must pledge to keep up the spirit of his wisdom and pass it on to the up coming generations!
Faraday88.Last edited by Faraday88; 09-13-2018, 07:14 AM.
Hi Dave, thanks for posting that. I don't remember seeing it before.
I'm going with 350kHz on Fig.8
Thanks Dave you made my day great post!!!!!Originally posted by Dave Wing View PostI thought I would repost this diagram that was found in a video made by Davy Oneness, it is a pictorial tribute to John’s work that is combined within an interview with Dr. Bob Hieronimus. The original image was not very clear...this one is much better.
Looking at it after I posted... it cloud be 350KHZ not 350MHZ.
Questions:
In figure 8 of John’s drawing he shows a hand drawn scope shot of the spikes with their peaks showing a wave apparently at 350MHZ. I have seen a similar waves in both the SSG rotored and solid state versions, but at low frequencies far below 100KHZ, I also have never gone over 150KHZ in my experiments either. Anyone want to add any insight into this?
Also if we need 350MHZ switching speed to accomplish this has anyone done this? If we switch fast enough no current should flow and we should not destroy the dipole, or at the very least limit destroying the dipole to the extreme. I also remember Bearden proposing 98 percent aluminium and 2 percent iron wire to achieve similar results. I remember erfinder showing self oscillation spikes that increased in magnitude and frequency as rotor rpm increased.
So I guess the real question is why did John include figure 8 in this drawing?
How the SSG works
