Originally posted by DMANN
Yaro has shown incredible results with Aluminum so possibly John's original thinking on the ZFM was not completely correct. It definitely isn't the only way the motor will run. Iron would be heavier and would give a better flywheel effect - the aluminum would be lighter and dragged down a bit by the field from the coils, but apparently not that much according to what Yaro has already shared with us all.
I just saw that your rotor is 2.5" diameter.
If you use a square magnet 3/4 x 3/4 by 1/4 thick, you'd get more magnetism into the same slot compared to a disc magnet - about 20% more if they're the same N rating: http://www.magnet4less.com/product_i...products_id=29
If you can make a 3/4 x 3/4 slot, then everyone could either put a full size magnet in there or maybe half magnet and half iron - the slot could be used both ways to compare.
Here are N52 3/4 cubes: http://www.magnet4less.com/product_i...oducts_id=1010 with 76 pounds of pull on each one. If they're 3/4 x 3/4 discs, they'll probably be 63 pounds of pull ballpark.
