Originally posted by RB176
The Street Fire is about 89 mJ per cap dump - it's around 2uf, which isn't much. After 3000 rpm, there can still be multiple sparks. Low rpm 6-7 per fire and as it goes up, it reduces bit by bit because the cap charging circuit can only charge up so fast.
The speed that the cap charger won't change the plasma - just a plasma will happen whenever the cap does discharge. If it is once per trigger, then you get one plasma burst per trigger. If it is 6 per trigger, then you get 6 plasma bursts per trigger.
3 ohms isn't much but I would recommend a coil intended for capacitive discharge systems. I like the Pertronix one because it is fairly low cost for a performance ignition with really low resistance in both the primary and secondary. 0.32 ohms primary - https://www.amazon.com/gp/product/B0...SIN=B002Q363XM only $45 delivered on Amazon prime. MSD has coils with much lower resistance if you can imagine that but they're a few hundred but not necessary.
