Hi Jeremiah,
I wouldn't do that. The MSD 5520 street fire works fine with the MSD 8222 blaster coil in my single cylinder generator application. However, the Granatelli solid wire may be too low of a resistance. I'm using a Taylor Spiro-Pro wire which has a magnetic suppression core found here. https://www.summitracing.com/parts/tay-45429/overview/
And I have a high temp, high voltage wire from the diode directly to the spark plug terminal. And I'm also using an NGK BU series surface gap plug. These come in various length reaches for a variety of different engines. I think the one that fits your engine is this one. https://www.summitracing.com/parts/ngk-703
This setup gives me a very strong plasma and long plug life as well. Here are photos of it again, in case you missed it in one of my previous posts linked here. http://www.energyscienceforum.com/sh...ll=1#post29910Last edited by Gary Hammond; 06-16-2019, 12:06 PM.
Hi Jeremiah,
The taylor spiro-pro wire is 350 ohms/foot. It has a magnetically permeable core with a thin steel wire tightly wound around the core.The Granatelli are 0 ohms what are the Taylor wires for resistance?
I posted the link to that old post so you could see how I installed the components on the single cylinder gen set rather than to watch the video. But glad you liked it anyway.
If you have an old cast iron K321 flat head it should be a 7/16" reach plug. I always used Champion H10 plugs in all the old cast iron Kohlers. The 1/2" reach surface gap should work great in that engine, as there is no projection beyond the end of the plug. Mechanical interference should not be a problem.
Thanks Gary, a friend of mine has some Msd 8.5 Super Conductor wire with like 50 ohms per foot same thing I believe Msd recommends for the Street Fire and he said he would give me some and all I have to do is put ends on. I may give it a shot it’s free.
Another update on torque masters spark plug:
1. Resistor TM plugs did not behave as claimed, it did not automatically break down the resistor despite of running 5000kms as opposed to claimed 200km running in
2. I ordered second set of TM plug with non resistor non projector variant after finding out equivalent NGK non resistor part number (can't believe why they couldn't suggest non resistor TM part number without me having to dig through 1000s of NGK models), this made the plasma blasts that I was after. Fuel economy is much better than resistor variant (10% better than resistor torque master, YMMV) and emissions all time lower with increased pickup and torque. With lean mixtures (by installing 105.7 vs 115 main jet) it had detonation after quite a bit of riding.
3. Longevity of these plugs I haven't tested out yet since its only 100kms I have driven in total)
My next plan is to build custom jet needle in Yoshimura multiple jet needle design style.
For this I have ordered 2mm stainless steel capillary tubes and tungsten drill bits
If I end up successfully with this design I expect better performance and much better fuel economy. Might take a month for the order to deliver and a lot of time to make the setup working after numerous trial and error.
I expect the end result to perform somewhat like in below video:
My ultrasonic experiments had to be put on hold because ultrasonic mister requires constant water level to be maintained which invites more setups like separate container with float level adjusted accurately, which I don't plan to do anytime soon because of the unavailability of small components, still searching for suitable float setup though. Ultrasonic fogger can easily melt plastic if tipped over (very risky business if not setup properly), but I will definitely try it out someday. I need to fix my fuel delivery once and for all, that's my top priority now.
Right now it's just unnecessarily wasting fuel past 3000rpm (as tested by emission testing center) even though its delivering record breaking fuel economy
Here is an update on our plasma ignition. Note, only the blue capacitors are connected. We have been experimenting with Aaron's plasma ignition system with our new pulse jet engine coupled with tesla valves used in the correct way. The plasma ignition makes a huge difference in the ability to burn whatever gas or fuel we use. I show the difference between nothing in between the gap, and something to burn in between the gap.
Here is the link
This may be of interest for your ultrasonic setup: https://eagle-research.com/product/f...circuit-board/
I'm willing to wager that it could be used to monitor water level and remind you to fill the reservoir, and shut the mister off
Hello.
I seem to have run into another problem with the Murakami set up (I think) One engine that covers some miles seem to burn plugs, fast. Like, a plug dies roughly every 700 miles. Not the same cylinder. Random. Replace the plug and it runs fine again until the next one dies. Plugs are NGK BP6HS. Are we just really unlucky to get bad plugs or could something else be the problem?
Torben
You can try a surface discharge spark plug, (I am using NGK BUE), which seems to has unlimited life with the plasma ignition. No wear signs thousands of kilometers after.Originally posted by Alstrup View PostHello.
Torben
But this is not the only point of superiority for such a spark plug...The Syncro Heresy
No doubt surface discharge type lasts longer than j type electrode. Alteast with my experiments with non projected torque master surface discharge non resistor spark plugs last longer than j type plugs. When I removed the j ground electrode completely from cheap Chinese non resistor plug it performed way better than torque master due to larger electrode gap. Larger gap is the key to better performance. Need to try out higher ignition voltage along with larger gap and plasma...
