Originally posted by Gary Hammond
Ron has the white trigger wire which is for mechanical points and the red small wire, which is for the ignition switch positive to turn on the MSD going to the distributor instead of the violet/green wires. There is no way it can ever work correctly like that.
Igniters aren't the problem - I did it in my Subaru and it has an igniter and I did it with the wasted spark ignition on top of that, which some thought was impossible until I did it. Of course the way I invented to make it work on a wasted spark ignition coil pack system with isolated secondaries with opposite polarities on each end is a bit elaborate but is the solution.
In any case, I think the correct trigger wires on the msd has to be used and the small red wire needs to be on the + switch on the ignition or manual toggle switch to the + of the battery and it should work fine. Even if it doesn't wind up working, it has to be wired up correctly to begin with in order to assess what the deal is.
Leave a comment:
