Originally posted by Mika
Motorbike coils are not designed for how many times per revolution a rotary engine needs to fire per revolution.
Rotary engines fires THREE times per revolution per rotor. Each rotor is busy with all the 4-stroke stages, each stage separately at a different part of the rotor, per each revolution. The casing around the rotor separates each stage. Therefore you need only one spark plug (some rotary engines have 2) per rotor.
Standard Rx-8 ignition coils, just like any other OEM ignition coil, have to much impedance (or resistance if you like) to capacitive discharge.
But you now have 3 options:
(1) Just piggy-back a CDI with your spark plugs - it is known by many names, but it is just a CDI with an external addition of a set of HV-diodes per spark plug.
(2) Convert the whole ignition system to a CDI ignition setup including coils - then add an HV-diode set per coil.
(3) As per #2 above with the addition of the booster system of #1 that you can switch in and out as needed, and/or have cut in somehow in ratio to the amount of air drawn in as measured by the MAP sensor (variable resistor setup connected to the MAP).
Just like any other OEM system, you can take a 2-channel CDI (like the ones specified for wasted spark ignition) and piggy-back it on the spark plugs, at the spark plugs, with one channel per spark plug.
REGARDING OPTION #1:
If you look through this thread and read Aaron's 'Ignition Secrets' book, you will see that for each CDI channel, and therefore in your case, for each of your engines 2 spark plugs, you just need HV-diodes between the spark plug and one polarity of the CDI of one channel, and the other polarity output of that channel to ground (any engine nut not to far from the spark plug). Likewise for the other spark plug with the other channel of the CDI.
I'm sure MSD, Mallory or so, will a CDI for a RX-8, since rotary engine cars have been involved in racing and many more in street-racing for many decades now.
REGARDING OPTION #2:
Low-impedance, high output voltage, automotive ignition transformer coils (NOT the old "cylinder" type) are the best suited for capacitive discharge ignition application. With these transformer ignition coils you have another advantage: the HV output polarities can be identified - one (+) and one (-). HV (+) of one coil goes to one spark plug, and the HV (-) to ground, and the same with the other HV coil for the other spark plug. Then you just add an HV-diode set per coil.
I LEAVE OPTION 3 FOR YOUR DISCRETION.
DIODE ORIENTATION for Piggy-back CDI (first option) depends on your existing HV-output polarity...
if it fires (-), diode goes between spark plug and CDI (-) output, with diode arrow pointing TO cdi (-) output, and the CDI (+) output taken to ground. This is done for each spark plug each connected to it own CDI channel. This will prevent the HV hitting the CDI, and the moment the HV breaks-down in the gap there is a closed conductive loop between the CDI output terminal over the spark gap, with almost no resistance, through which the CDI will discharge.
if it fires (+), diode goes between spark plug and CDI (+) output, with diode arrow pointing TO spark plug, and the CDI (-) output taken to ground. This is done for each spark plug each connected to it own CDI channel. This will prevent the HV hitting the CDI, and the moment the HV breaks-down in the gap there is a closed conductive loop between the CDI output terminal over the spark gap, with almost no resistance, through which the CDI will discharge.
Option #1 does work, and has done so for many - I personally believe that the Murakami Ignition - Option #2 - can be more effecient.
ANOTHER ADVANTAGE YOU HAVE IS THAT YOU MIGHT ALREADY USE SURFACE DISCHARGE SPARK PLUGS - THEY PROVIDE BOTH SPARK GAP CAPACITIVE AND INDUCTIVE ADVANTAGES FOR PLASMA IGNITION, UNIQUE TO ONLY THE SURFACE DISCHARGE SPARK PLUGS.
But, spark plugs, no matter which plasma ignition you go for, and the spark plug wires, MUST be ZERO RESISTOR type!!!
