I had an opportunity to print the latest BC Window motor file today. I got to say that I think it turned out beautiful. It is much more robust than the original design using the tabs in the four corners. It also allows more mounting options as you can remove the gray parts and just use the four holes on the bearing ends. I just need to throw some wire on and give it a circuit and it will be ready for experimenting.
running on the Full Sequential Bipolar Circuit.
