The SG Radiant Oscillator
  • #91
    Howard, it's a Christmas decoration I can guess that John B wound two of them to see if both in series or parallel or just one by itself worked better Or maybe he already had the coil lying around.
    @John B, care to solve the mystery of the extra green wire?
    In post #40 Was where I got the idea that you could use one trigger strand if wanted when using the transformer function. When I hear transformer function I always think of pages 46 and 47 of FEG. 46 being the solid state version.
    So my prospective was that If you were using the transformer function, you could use one trigger. But if not you would use one trigger per transistor.
    But it could also mean that he had the extra wire there so he could play with the transformer function if wanted and was just an extra wire hanging there when not in use, and there is no such thing as more than one trigger wire.
    I just seems to me the lameller currents would not have the same effect without a trigger strand per transistor...
    Or I could just plain have the whole thing wrong from the ground up(most likely).......
    Les
    • #92
      This is how I've been doing it:
      [ATTACH=CONFIG]599[/ATTACH]
      Patrick A.
      The bottom of the trigger winding going to the primary positive forces the trigger thereby turning the, normally mechanical/rotored, SSG into a precisely controlled solid state oscillator.
      Patrick A.
      • #93
        Les
        I assumed and just went back to double check the recent videos - John B. has both of the green wires in parallel for the trigger. They are definitely connected together at the primary + and the other ends terminate to the middle of the split 680 ohm resistors - that is the two 680 ohm resistors and the 2 green trigger wires are all connected together, then each of the 680 ohm resistors go to the bases of their respective transistors, just as I drew out in the diagram above minus the CPD mod . I found that with the SS, my coils with the thicker trigger wire do a better job triggering the transistor. They pack a bigger punch to the base. It's all a balance though right...
        Patrick A.
        • #94
          Patrick,
          I think your right! That makes the most sense. Simple!
          Les
          Patrick A.
          • #95
            Patrick A.
            Patrick, does that mean that you are running this circuit in SS mode without the B-C resistor and the diode instead of the B-E resistor? Interesting.
            What sort of results are you getting?
            • #96
              "I have since removed them from my setup as well.
              Cheers to Tyson...
              sincerely,
              Patrick"
              Yahoo! Groups
              With so many posts it's easy to miss the ideas that fly by...
              Patrick A.
              • #97
                Some transistors will not begin to fire on their own. They will need a little kick start.
                see if you can find it:
                Patrick A.
                • #98
                  Cheers to Tyson...
                  sincerely,
                  Patrick"
                  Yahoo! Groups
                  Patrick A.
                  Patrick
                  are you using 680 ohm resister for transistor Base same as John B. did or you you are using different value ?
                  What is the value of the resister after the pot. And it seems that you use polorised cap and your previous setups you used nonpolorised cap ?
                  When I check Tyson setup he connect the E diod to the neg of the primary only and not connected to the Base as well did you find that work butter?
                  Ehsan
                  • #99
                    Patrick A.
                    I've got to say that's what I think I'm seeing as well, but since John K sees something else, I'm hoping John B can clear it up for us. I think I'm seeing that, but wouldn't swear to it. It's just not that clear.
                    h
                    • Originally posted by Ehsanco1962 View Post
                      Patrick
                      No
                      This is all part of the tuning. and unless you are using it as a branch resistor, you can tune it to the point where you do not need this extra resistor and use a fix resistor instead of the POT.
                      Yes - check it out on the scope w/ and w/o you'll see :-)
                      Ehsan
                      Ehsan, these are all good questions and if you play around with the setup for a few hours and take good notes, you will get a good feel for how it works. Let me know which cap you end up using, I'll be curious which type you find works best.
                      I'm still learning the basics and continually look forward to John B's explanations and experiments.
                      Kind regards,
                      Patrick A.
                      • Patrick
                        Thank you for the clarification I sure will check it all out with the scop .
                        Ehsan
                        • Hi John,
                          Want to check circuit hookup with the 2 trasistors.
                          Trifiler coil?
                          Don't see the emitter to collector diode ala US7990110 B2
                          bro d
                          • Mr. Bedini
                            1. What kind of POTTING COMPOUND do you use?
                            2. How much is it?
                            3. were do you buy it?
                            Thank You, Have a great night.
                            Geoffrey
                            • Hi John!
                              A post to Mr. Bedini from Geoffrey sr Miller about an EXP. on a dry cell battery.
                              Hi Mr. Bedini
                              My name is Geoffrey miller this is my first post ever on any forum, I have followed your work since the late 70's.
                              and all the other people in the "Free Energy Field." I have my owen lab that I work out of. I have built your sg units and they work Great! From little to big ones. I also have your first books from the 1980's.
                              The reason for the post is, can you provide a circuit diagram and parts list of the post from 2005 consering your EXP. of,
                              "Experiment with the one wire system that Tesla developed."
                              I have done radiant EXP's of Tesla for a very long time. with 12 foot coils.
                              I would like to run your EXP. on a small to a big scale.
                              IF you want to send the info off line here is my e-mail [email protected]
                              Hi John,
                              I ve been following your work since 6-7 years now and was in tune with the latest updates in your website.
                              i have tried to replicate most of your beautiful looking machines on the website with good results and a proper understanding of the Radiant Electricity Physics behind the succesful replication.
                              it is a privilage of life time to have a person like you who has spent decades on the development this magnificent Science of Tesla.
                              I will soon post with pictures of my Replications of your Machines. this i regard as a mark of tribute to you John.
                              Bye for now,
                              Best Regards,
                                Geoffrey,
                                Yes I understand what you also have gone through, But we must move on. What will happen is inventors will just make it very difficult to steal circuit and inventions. I for one will hy-bird everything. Congress has no touch with realty anymore as they never worked a real job, they just suck money, and that is just an example to the young people, you can steal what you want and it's ok. But hopefully we can all move on and build something for the future.
                                Hi John,
                                it is a boon to a Free-Energy Inventor like you, where the very Nature of Radiant Electricity shows up it self in different variants to make it convienent to be Engineered in avarity of configuration to avoid duplication and reverse engineering .
                                rgds,
