I wanted to recap on how important it is to use good batteries in your experiments. I think most people who are replicating and experimenting with the SSG Monopole Energizer spend more time on trying to get the machine to work properly than focussing on on the batteries they are using. This is why I think most people are not getting the results they should be getting.
It doesn't matter how good your machine is built or how well you wound your coil, matched the components or what your free spin time is IF you are not using good batteries! I have seen this over and over again on the bench - bad batteries = bad results, good batteries = good results!
So how do you know if you have a good battery or not? Here's a few tips:
1. Use only flooded lead acid batteries. Other battery types will work, but until you get good results with flooded LABs and fully understand how they work, what they like and don't like and what their charge and discharge curves look like don't try other battery types.
2. Size the battery to your setup, or more importantly, size your setup to your battery. This is something you will need to experiment with and get a feel for from experience. As a guide, the most basic bifilar SSG on a bike wheel rotor is good for a 3Ah motorcycle battery. The 8-filar bike wheel kit is good for a 13Ah lawn tractor battery. Anything bigger and you are looking at a very well built multi-coil system.
3. Get to know your battery. One of the first things you will want to do with a battery you haven't worked with is to develop a charge and discharge profile. There are tools on the market like the West Mountain Radio CBA, but you can also plot your own charts by manually recording voltage readings at regular intervals and plotting a chart in Excel. When discharging, you will want to know how healthy the battery is by load testing it. That is, load the battery at the C20 rate and calculate the Amp hours or Watt hours the battery can deliver. Repeated charge and load tests will give you a battery profile.
4. Never exceed the charge or discharge termination voltages. If you want to keep your battery, treat it nice. Search for the battery's specs and stick to them. As a guide, never discharge a starter battery below 12.2v or a true deep cycle below 10.5v. Conventional battery chargers or "quick" chargers will kill your battery by forcing current into them which causes heat which will warp the plates and shed the active material off the plates, eventually causing shorted cells.
5. Is that new battery really "new"? New batteries these days are getting worse and worse. They are designed for you to replace them every 3 years. The plates are thinner, they are not formed properly and the lead in them is of poor quality. Most batteries are already sulfated when you get them. The tip here is to run them through a few cycles until you start getting close to the rated capacity of the battery. Be especially cautious of dry charged batteries - my tests are showing that these usually need a lot of cycles to get them up to scratch.
Hope this helps...
Hope this helps...
