I have read a few things on the forum about batteries but just wanted to consolidate them in a thread if possible.
Those are just some questions I have come up with, if anyone has any experiences they would like to share or sound advise then please share your knowledge for the beginners!
James
- Is it ok to start charging a brand new or near new battery with a radiant charge or does it need current to form correctly?
- You cannot swap a radiant charged battery to the primary until a certain time has elapsed, how long should you wait?
- Is it ok to mix radiant charge with a current charge from a comparator for example, say half way through the charge?
- Does charging the battery with radiant and then later charging with a hot charger and back and forth ruin the battery?
- What's the safest voltage a battery should be discharged to. I read you generally should avoid going below 12.25V.
James
