The beta multiplier is a Gyrator circuit, it uses a small capacitance to simulate a large inductor (without the backemf), so the beta multiplier is like a choke. (a big coil in series).
Changing the voltage to the base of the beta multiplier, is changing the output voltage at the emitter of the beta multiplier..
If you had 10 watts available in the pre-filter cap, you can chose to have it served as
"10V @ 1A"
or
"1V @ 10A"
according to the controlling voltage to the base of the beta multiplier.
The beta multiplier and the pre-filter cap, make a power source with adjustable impedance. So you can adjust your voltage current ratio.
Because the beta multiplier is an inductance simulator, this provides a very high impedance to high frequency's, so they don't pass through.
The radiant spikes are now allowed to charge the pre-filter capacitor, without getting loaded, only the DC component is allowed to pass the beta multiplier.
The impedance of the battery is sensed, and a special feedback voltage, (that represents the battery impedance), is fed to the beta multiplier, this achieves automatic impedance matching. Between the beta multiplier and the battery, for maximum power transfer.
The command voltage (set by your voltage adjustment), sets the impedance/voltage threshold, of what the battery charges to.
"10V @ 1A"
or
"1V @ 10A"
according to the controlling voltage to the base of the beta multiplier. The beta multiplier and the pre-filter cap, make a power source with adjustable impedance. So you can adjust your voltage current ratio.
By the way "Ecancanvas" I really like how your circuits are neat and tidy, nice work.
Once I have nice stable voltage reference, I will have a stable circuit.
"Ecancanvas" you have figured out the impedance sensing of the battery without knowing it. I could not really understand the phrase "The emitter resistor that balances the emitter", unless it is a current source..
