Ronnie,
Very cool system. may I ask you a few questions? (well I'm going to anyways..)
- are you running your coils solid state or on a wheel?
- if a wheel, what size is it and are all the coils around the same wheel?
- you say you have about 250W of solar panels and run a 2500W inverter.
Do you have meters before or after the inverter and between the panels
and first set of alum batteries?
I'm obviously trying to get to the numbers here and how much the SG is
amplifying the power you're gettin from your panels.
I see that this is over a year old, did you finish your build completely yet?
Are your inverters grid-tie inverters or 'regular'? and would you mind sharing
which ones? thanks
which ones? thanks
there is also a thread over on energeticforum.com the ferris wheel is not the SG its a Bedini cole switch and a cap discharge circuit.
