Explorations of the Bedini Ferris Wheel Motor Energizer
Here are pics of the Ferris Wheel Hub Motor Timing wheel. When I received the FW, the 5, 1/2" magnets on the timing wheel were missing. You could clearly see where they had been glued down. So I replaced the 5, 1/2" magnets on the Timing wheel with new ones as talked about in the FW EFV-23-2010-Tech Review video.
This video shows the Hub Motor pie shaped magnets field shape using Ferro Fluid
This video shows the Hub Motor pie shaped magnet field using brake drum/rotor filings that were rusted, and used for various experiments over the last few years.
This is "20191121_203036" by RS Stafford on Vimeo, the home for high quality videos and the people who love them.
Several years ago, I Put a SG/cap pulser coil into a plastic tub w/ lid full of these filings, and then running the SG was a very interesting experiment. Changed the Oscope wave forms and operation in ways i did not expect.Last edited by RS_; 03-11-2020, 11:03 AM.
Hey RS,
Great and detailed effort in showing the inner workings of the Bedini FW. The experiment depicting the magnets' field is excellent using the Hall sensors in combination with the Oscope. The field shape is reminiscent of the induced field in the ZFM as the rotor Neo's pass by the unpowered coils - makes sense to me anyway,
The sharp spike at the narrow tip of the magnets demonstrates the concentration of the magnetic field well. Very nice and informative!
Thanks for sharing and looking forward to more as you progress.
Very interesting - the wavform is identical to the Kromrey waveform. I wonder if that was intentional. Of course this is the magnetic field and not the output of coils, but still very interesting!Originally posted by RS_ View PostVideo of the magnet field sensors over the center of the pie shape magnets on the hub motor
https://vimeo.com/373775430?utm_sour...campaign=28749
https://vimeo.com/373775430?utm_sour...campaign=28749Last edited by RS_; 03-27-2020, 09:59 AM.
For this series of experiments on the Pie Shaped magnets on the FW Hub Motor I used the Linear Hall Effect magnetic field sensors A1326LUA-T A1324LUA-T.
The A1324/25/26 feature factory programmed sensitivities of 5.0 mV/G, 3.125 mV/G, and 2.5 mV/G, respectively.
Order today, ships today. A1326LUA-T – Hall Effect Sensor Single Axis 3-SIP from Allegro MicroSystems. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Order today, ships today. A1324LUA-T – Hall Effect Sensor Single Axis 3-SIP from Allegro MicroSystems. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
The Hall Sensors are used with a OpAmp circuit PCB that I designed about 15 years ago based on this web site:http://www.coolmagnetman.com/magmetr1.htm
This OpAmp circuit scales the Linear Hall Voltage output so that it reads +/- 8.80V = 880 N/S Gauss (A1326LUA-T), or +/- 4.40V = 440 N/S Gauss (A1324LUA-T)on a meter or Oscope
In the Pic's/Videos the clear Pin sensor wand is the A1326LUA-T, and the grey Pin sensor wand is the A1324LUA-T
sorry for the fuzzy pic taken during calibrationLast edited by RS_; 11-20-2019, 12:06 PM.
In 2016 I was blessed to acquire 4 of John Bedini's Models, the medium size Brown Pendulum, the 6 Coil SSG, the Ferris Wheel, and the small Brown Ferris Wheel. In 2017 I did the presentation on the Poor mans 4 Battery swapping system using the 6 Coil SSG as the 24V load, charging 3 banks of 24V battery's swapped out to run a inverter running various loads.
Then I had to Move, delaying working on anything until I could get a new shop built at the new place.
Now that the new shop building is built, and the Ele & Solar installed to the building and back to the house, I will be able to erect the Ferris Wheel in the new building and get it going.
In 2019 I did a short presentation at Energy Science Conference announcing a Go Fund Me, to help me fund studying and upgrading the Ferris Wheel to demonstrate what all it can do to generate power.
https://emediapress.com/2019/08/21/f...s-wheel-motor/
new go fund me link:
https://www.gofundme.com/f/bedini-ferrris-wheel-investigation-amp-upgrade-2?utm_source=customer&utm_medium=copy_link&utm_cam paign=p_cf+share-flow-1
Please check the URL and try again or, alternatively, you can browse fundraisers currently receiving the most donations worldwide below.
I will then bring it to the 2020 Energy Science Conference to demonstrate what all I have found and upgraded.
In the mean time, I have started the Explorations of the Bedini Ferris Wheel Motor Energizer starting with the Hub motor with the pie shaped magnets in my new office. Over the next few month's until the 2020 Energy Science Conference, I will be posting updates of that Exploration here in this thread.Tags: None
