UFO motor/ 3BGS - YouTube
UFO/ 3BGS test 2 - YouTube
3BGS Test 3 - YouTube
Mr. Bedini, I hope you have the time to comment on this. It is your baby. I just happened to get extremely lucky with some combination I still do NOT understand. You may believe i am full of crap, but I know what I saw, and I was lucky enough to get the thing working a few days ago just like the original device. If you think I am full of crap, I'm sorry, because your opinions and ideas on this would be much appreciated. Regardless, I will continue working on it, because once you have seen what is possible, nobody can convince you that you haven't seen it.
The setup I had working JUST LIKE THE ORIGINAL (which means charging the primaries while there is a load on the motor and a load on battery 3) a few days ago is no longer working as well as it was, and I am not sure why. When I took my motor apart, one of the four brushes that make up the power input circuit was not making contact and two of the 16 sections on the armature (which by coincidence were nearly 180 degrees from each other) were not making contact. This is a UFO modified motor, so it has two commutators, and the two sections on the armature were "dead" which COULD mean it was acting more like a pulse motor. I do NOT know when these problems occurred. So any one of these three "problems" may have been why the motor was so successful in the videos I show here, OR SOME COMBINATION OF THESE PROBLEMS, or it could have been the timing. Those are the variables. All three of the problems are now fixed, and it still isn't working like it was.
I hope this is of interest and not too far off topic for this forum, since it IS based on something Mr. Bedini published.
Dave Bowling
Dave Bowling
