I am fascinated with Nathan Stubblefield's earth phone and purported earth energy extraction devices.
I have been doing some basic beginner type experiments such as burying a brass and aluminum plate on a North-South oriented line about 100' apart and seeing what kind of voltage I can get. Those plates produce about .4v-.5v. Today, I pounded a steel rod into the ground and used that instead of the northern most plate. The potential went up to .72v I then pounded a tent peg into the ground right at the foot of a small tree (something Stubblefield was said to have done) and the potential went up to 1.111v! However, when I tried to connect an LED between the two, the voltage dropped to nothing. I remember Tom Bearden saying that as long as you don't demand any current, then the inexaustable potential is free for the taking. I think J.B.'s oscillator is the key to using this energy on small loads like LEDs. Tom also stated that an elevated wire can produce 200-300v per meter. I am a little unclear about how to do that. Is the wire elevated vertically like an antenna, or is it a horizontal wire suspended between stanchions? Also, is the wire insulated, or just bare? I put up a length of insulated wire mounted vertically on top of my house today to see what I could get, and there was absolutely NO potential difference between it and any of the grounds, so that does not appear to produce anything.
So, I decided to start a thread here about earth energy systems and experiments since I didn't see any on the forum. If you have been able to obtain any success with earth energy extraction please post with your results!!
-Woody
-Woody
