Thank you RS I will try to join that forum.
I looked the google site of the coil shorting when you post it the other day, I learned that I need to use 2 transistors/FETS to shot the coil /because of the positive and negative sine wave.
your paying for a small AC current on a low voltage primary to make the voltage peak on a high voltage secondary, that you only short on the peak, so no current flows during the ramp up to peak, and the fall down from peak, and you harvest the ringing into a cap......
