This is how Walter Russell viewed a magnet. Notice the low pressure long waves and high pressure short waves. In JB's vid onthe kromrey he says something like "the highest you can get with this coil configuration is 300 something but i can get it up to 400 something" well if what i am thinking is correct and Walter russell is correct about the magnets...then if you put different impedance coils that make the poles concentrated as in the photo maybe it would increase the reaction by getting in more in line with nature. for instance if you wound the "three coils" that Bedini talks about in the kromrey but instead of a trifilar coil you make three coils that you attach in parralel so that you achieve the low impedance he was talking about but in that one impedance... one coil could be lower the other two higher ....to me that sounds like it would mach the russell picture. put more windings on the two coils where the poles should be more concentrated " center of bar and end" and put less on the center coil.
If you also look at the bar magnet in terms of normal coils if there is a permanent double pole in the middle and you only ever make a one way coil....you will always fight the other side. Maybe the two coil idea is the key to allowing current to flow without always wanting to destroy itself by flowing.?
