Aln's edited notes from Erfinder's discussions.
  • #46
    To come to some agreement, we would first have to come to an agreement regarding the forces that we call attraction and repulsion and what they represent, i don't believe the classical explanation one bit.
    In my veiw which is nothing other than a primitive comprehension of Russell, attraction is the result of an external pressure, repulsion is a result of an increase in gradient between, like poles 'attract' dislike 'repel' what they 'see' comes from the other side of the magnet bar which is why it appears that opposites attract, in assumed reality this is the same as why light is upside down in your retina.
    • #47
      Aln - the magnets have the equatorial poles on them on the equator! (they can also be virtual in respect to something that creates them?) think of a cross, each is a vortex, this is your magnet, it is also the same layout as stuff in space.
      • #48
        • #49
          particularly liked page 24, i have a sketch book with identical drawings i did a year or so ago, i was looking at them just a few hours ago all this talk of four poles reminded me. strange how stuff like this happens.
          • #50
            if his description of using the equatorial poles on a magnet is what is being spoken of there are only 2 choices. we know he is switching at the junction of the 2 coils when the magnet crosses the interface of the 2 coils. . looking at the wiring that Dave posted this means that we need to draw the sine wave out and look at what the coils are doing at sine wave peak and at the zero cross. with that known we can discern how the magnets are in the rotor. they are either regular north and south out. or they are in the rotor sideways which gives a north on one face and a south on the other. this also creates a scalar north and south in between poles. it actually changes how the rotor looks magnetically. this is just my guess.
            • #51
              That is a really good book i will read it all, thanks guyzzemf
              this is a better picture
              • #52
                has he not already told us he has an alternator rotor 'regular' nsns? and yes he is probably switching at that position JTDC like what krill has published on youtube.
                • #53
                  yes he has. so if so why the cryptic description of the coil rotor arrangement.
                  Tom c
                  • #54
                    the reasoning behind the layout?
                    • #55
                      Yes, I know, show me where the poles are on the equator. Then tell me how you increase them.
                      (they can also be virtual in respect to something that creates them?) think of a cross, each is a vortex, this is , your magnet, it is also the same layout as stuff in space.
                      This makes no sense to me the way you wrote it. It is in refrence to something you read that I have not. Specifically,
                      "think of a cross, each is a vortex, this is , your magnet"
                      I inserted a picture of the 4 corner spins in my post about equatorial poles, which is what I think you might be talking about. Here is another with the corner spins and the vortices associated with them from H. Johnson, whom erfinder referenced. Click image for larger version
Name:	magnet vortice.jpg
                      Conventionally, magnets were thought of as having 2 poles with a magnetic field like this: Click image for larger version
Name:	conventional magnetic field.jpg
                      Magnets according to erfinder are 3 pole devices. (He used adams motor diagram to explain)
                      Magnets to BMW are 4 pole.
                      We need to talk same language and have same meanings for words to comprehend eachother. I was trying to put glossary together in alphabetic order but magnets need to be discussed here now. Here is what we have from erfinder:
                      Magnets: The polarity of the magnet is characterized and or defined by the wave that it generates, if you know what to look for, the three poles become as clear to you as the nose on your face.
                      I shared that image with the three coils and magnets because that's where I started. After studying that drawing and other material it became clear to me that magnets and electromagnets are three pole devices! The image allows one to more or less come to that same conclusion. When you look at the image, prior to considering the output waveform, it is necessary to see what polarity is being induced in the coil and when. The image emphasizes the significance of inducing both on the approach, and receding, simultaneously. Presently, the books cover the two sequentially. I have found that inducing at both points has a powerful positive influence on the negative effects associated with Lenz's Law, the problem has been misinterpretation of the relationship between inducing and induced.
                      Many in the know understood/understand the significance of this. They all incorporated an offset in at least one of their designs.
                      Muller
                      Adams
                      JB (Watson machine)
                      See what I mean by three poles in one, and how it is imperative to proper operation that the coils are properly related to one another, both electrically and geometrically.
                      UNIDIRECTIONAL FLUX, Although attraction mode is superior to repulsion mode, the separation of the two isn't what we ultimately want, we want both modes. We want to use both sides of the magnet, and here I'm not so much talking about the poles, in this particular instance, I am talking about the corner spins of the magnet. The north pole of the magnet contains multiple orders of spin, however, only two are of immediate interest. Flux leaves the north pole in a left handed spiral, and a right handed spiral. Flux leaves the south pole in a left handed spiral and a right handed spiral. H. Johnson shows you this in his work, we were re-introduced to his work by JB. It's my opinion that H. Johnson's work applies to JB's work. JB suppresses one of the corner spins in a manner similar to how H. Johnson did, turning the SG into a kind of magnetic gate, when operated in attraction mode. Had I been preoccupied with doing what I am told, this connection would not have been made! After studying this for a while, when you start looking at the other technologies, specifically the window and zero force typologies, it becomes clear that once again we are dealing with rotor to coil corner spin interactions. At this point it hits you, how is this any different from what we already experience in conventional designs which have been with us for over the last 100 years. The answer shocked me, fundamentally there is no difference!
                      • #56
                        So I read over the context of the statement in question about normal and equatorial poles here and highlighting his comment, "Junctions are equatorial poles" we want more junctions, points between poles, to make the system more assymetrical. This I assume can be done with the coil, by switching at JTDC? So thinking about a comment by RS on the switching thread about ringing the ring, is that the same thing. Switching at JTDC creates a ring(sound/vibration/spike...) that in turn creates another junction-equatorial pole?
                        Erfinder 8/19/14
                        "What did I say guys? Does this fit what I said about looking between the turns???? NO! THE POLES ARE CONSTRUCTS!!! THEY ARE NOT REAL! MAGNETISM MOVES AROUND THE WIRE IN CIRCLES THIS MEANS WE ARE LOOKING IN THE WRONG LOCATION FOR THE "MAGNETIC POLE". THE POLE YOU ALL ARE PREOCCUPIED WITH IS NOT MAGNETIC......IT'S DIELECTRIC!!!!!!
                        The puzzle is big, must put the edge pieces in first. Aln
                        • #57
                          Some more information found here, many thanks to wattups... http://purco.qc.ca/ftp/Overunity.com...nder-posts.doc
                          -Dave Wing
                          • #58
                            man that was a long read. does not help that half of the responses have no context. still it was interesting. I ran into Erfinder on another forum a long time ago with the machine he was talking about in these posts. he refused to help anyone build and refused to say anything other than study the patents, if you don't get it you don't want it.... thanks for the hard work Dave.
                            • #59
                              I can't keep up with the reading, that's a good problem. Still stuck in the book by Ken Wheeler on magnetism. Thanks Dave. Aln
                              • #60
                                I think this is the thread if anyone wants to read it... http://www.overunity.com/133/free-so...-energy/nowap/
                                Here is another document compiled from the same thread... http://www.overunity.com/133/free-so...h/attach/9377/
                                -Dave Wing
