Looking for a magnets only motor
  • Looking for a magnets only motor
    Greetings,
    magnets have energy inside them, they are like magic, this is why I believe that their force alone can be used to make a motor.
    I experiment a little a while ago using Meccano parts to prototype but didn't get anything to spin.
    I came across many videos including the energy from the vacuum series but I never found instructions on how to build any motor.
    So I'm asking here to more experienced people, do you know of a working motor with building instructions that spins by the magnetic force of magnets (not electromagnets) and requires no battery or electric circuit ?
    the only one I know of that is "real" is howard Johnson's not the scam ones but you can read his patent here:
    The invention is directed to the method of utilizing the unpaired electron spins in ferro magnetic and other materials as a source of magnetic fields for producing power without any electron flow as occurs in normal conductors, and to permanent magnet motors for utilizing this method to produce a power source. In the practice of the invention the unpaired electron spins occurring within permanent magnets are utilized to produce a motive power source solely through the superconducting characteristics of a permanent magnet and the magnetic flux created by the magnets are controlled and concentrated to orient the magnetic forces generated in such a manner to do useful continuous work, such as the displacement of a rotor with respect to a stator. The timing and orientation of magnetic forces at the rotor and stator components produced by permanent magnets to produce a motor is accomplished with the proper geometrical relationship of these components.
      Hm, isn't that the magnetic gate thing ? If so do the crescent shaped magnets exist with the required magnetisation axis ?
        no you have to make them....
          By make you mean combine smaller ones as told on the DVD ? Thing is that, if I remember correctly, on the DVD it is not shown what shape are magnets and how they are ordered.
          If you meant magnetize them myself, then I must ask why no manufacturer in the world makes them, either some organisation prevents them, or it's not possible and then why put it in a patent.
            What Tom said, and while not a motor per say, I've seen Bedini demonstrate the Hamel whatever its called flying magnet motor, that's like a hobby shop project at the demonstration level. I also saw him write up, and I've not been able to find it again, I wish I had bookmarked it, an all magnet motor where he commented that it was confirming like three theories he and Bearden had on magnetism. There is also a fellow in Austria, Dietmar Hohl, who says he has worked off of Howard Johnson's principles. He gives detailed mechanical drawings and complete parts lists for his projects which last I saw he was claiming 2-5kW from, I suspect he is valid but it would cost you maybe 2K or more to get it all machined and try and build it yourself to find out.
              So there's nobody on this forum with a working motor ??
                I don't know about this forum, but how about this one - https://www.facebook.com/MagneticMotor?
                  not that I know of.
                    Here Is a Working Permanet Magnet Motor
                    I knew of one Motor that Work's
                    I found A ready to marketing project recently! It is so amazing and powerful that I'm very worry about the Inverter at the Moment.
                    The Motor is bean developt from A Turkish Man who workt on it for over 33 year.
                    His Name is Muammer YILDIZ, and in my opinion he is a very nice and honest Person.
                    I hope it will not disappear together with the Inverter.
                    and he have a patent on it!
                    Please see for your self:
                    the very existence of his Motor is threatening the every Petroleum based economy!!!
                    With other word all worldwide economy!!!
                    I hope he make it, but in y opinion his chance a very little!
                    Love and Light
                    BNW
