A quick bench test was done to test the old document regarding the S1R triple coils assembly. A neon bulb NE-2 was placed across the 2 end insulated wires to test for 100 volts coming from the bare copper wire under the S1R coils. The bulb did light up when the ignition was fired to spark plug. I had read way earlier that others had grasped the 2 wires and had gotten shocked.
The old documents also said that about 100 volts and 6-7 amps WAS REQUIRED- through the spark plug for the mineral water conversion of an engine. The other document was called the "60 turns coil test". 60 turns insulated wire over plug cables used to assist the 6-7 amps to spark plugs. Not tested as yet. A bench test could be done without an engine first. 2 spark plugs bench mounted as 1st to fire with ignition only. This gets the required magnetic field for the Briggs mower engine timing change and the cylinder process. The 2nd plug gets the amps , the low voltage, and the needed minimum 100 volts. There are 8 methods to do this, but the one done in 2008 was not exact talked about. The plastic tub mounted on the side of the Briggs engine of the 2 Youtube videos, was to hold the majority of added parts. To get 15 amps or higher output, a bridge rectifier would have to be used with the alternator. That type of rectification is not pulsing DC as with one diode. Pulsing DC can run a hand wound step up voltage autotransformer. Magnet wire wound on outside of the Magnetron could also generate the 100v as another secondary winding with diode. AN inductor 1.75 Millihenry was included and may have provided a back EMF of over 100v. This would be SUPERIMPOSED over the low 12-35volts DC. The same ground is used. The spark plug small electrodes IS THE WATER electrolysis cell. Untested as yet for bubbling action gases evolved. Water vapor pressure also contributed to piston compression.
For example, flashlight battery 1.5v turns on light of 1.5v bulb. When 2nd battery 1.5v is added in series, the bulb is twice as bright because of the 3 volts total. Therefore, if the engine conversion power supply 12-36v DC is in series with the safety diode + insulated wires turns from the triple S1R9A9M9 coils, the total voltage to spark plug is approximately greater or equal to 140 volts DC. DC is required to make hydrogen fuel from water. The tiny plug tips in combustion chamber need way higher voltage to get FASTER Hydrogen gas generated. The salt water droplets from eye dropper added to plug tips on bench test, forms ohms resistance electrical load electrolysis cell that reduces the first preset 6 amps on current gauge, down to .1amp. Therefore, much higher voltage is required to get the same 6-7 amps ,-----------JUST AS THEY SAID MANY TIMES IN THE WEB FORUM!!
Many years back, there were 2 other people confirming their wiring conversion DID operate their engine on water in carburetor at idle speed. The running engines on mineral water in carburetors was the successful 3 Georgia technicians' shop work done 2005-2012, and written up in the now closed web forum.
