The Meyer Hydrogen system is the 2nd best invention since bench top Cold Nuclear Fusion Heat. HHO is really H+ H+ O-- as charged ions. The gases have more energy total. The Patented Meyer term is Thermo explosive Energy. There were 3 systems. proof of design, concentric tubes water cell, and multi use injectors with electrons extraction, lasers and pulsed high voltage,- at pulse modulation. There are more gases evolved during off time as the on time. See Stan Meyer company manuals as,- Birth of new technology and Water Fuel Cell dealership Manual. Many Patents. The resultant true Meyer cell has thick, tiny, tiny, FOAM rising upwards in cell. All the rest is H2 with water vapor/ and or electrified water vapor large bubbles. Voltrolysis as >1500volts DC in plain distilled water.Deionized water was better. Two inductors resonated with cell and power source. Input secondary pulse through inductor to water capacitor as lowered volts to PREALIGN polarity water molecules. Then high volts DURING OFF TIME with vibration separates with no current, voltage pressure. Diodes make hydrogen, AC makes heated/ water. Very low wattage input. Overunity as huge efficiency. Power for engines and factory blast furnaces.
Stan Meyer Hydrogen Generators And Patents
