air as fuel technology ..
Air as fuel technology
Alessandro,
Are you "ionizing air into plasma" with no electrical input? Just the use of a magnetic field and a catalyst? As stated in the papers on D.H Baziev theory?Last edited by freefuelnow; 03-14-2013, 01:40 PM.
part of the phenomena that you describe should be present in the combustion phenomena as shown in this site
looks at the two test video at the end of the pageLast edited by mareazzurroo; 03-14-2013, 01:38 PM.
Sorry for delay of reply.. No electrical input is needed.. air can burn like gas and with an very calorific flame. The theory of Baziev is proved. Actually I'm working to increase the performances of plasma. In my actual model I use just catalyst without magnetic field becuase no need.Originally posted by freefuelnow View PostAlessandro,
Air as fuel surely is the future of world. during my tests I have found an fantastic discovery.. this special plasma is able to make new fuel molecules again ..Originally posted by Cary Karen View PostFuel technology is considered as a renewable energy, this kind of technology are made from carbon and this kind of technology are process of carbon for suitable energy.
Sorry the web site indicated from you isn't available..Originally posted by mareazzurroo View Postpart of the phenomena that you describe should be present in the combustion phenomena as shown in this site
The process is a chain reaction to work but there are variables to be respected , the most ' important' depending on the temperature and the catalyst used .Originally posted by mareazzurroo View Postciao Alessandro in un'altro sito hai scritto:
SORRY BUT IS COMPLETELY DIFFERENT ALSO AS FINAL REACTION..
HOWEVER I DON'T USE ETANOL OR METHANOL INSIDE THE REACTOR JUST FEW GRAMS OF PELLET!!
PLEASE COME TO THE EVENT HERE IN FLORENCE AND YOU CAN SEE WITH YOUR EYES THE AIR TRANSFORMED IN AN BLUE PLASMA FLAME TO HIGH TEMPERATURE!!
I HOPE FROM VIDEO CAN BE VISIBLE THAT ISN'T AN NORMAL COMBUSTION FLAME ..
questo significa che oltre a trasformare azoto bruci anche pellets il circuito è chiuso o hai un loop dove reimmetti i gas parzialmente combusti nel tuo reattore plasmatico?
I 've used as fuel wood pellets but you can use any fuel or vegetable oil present on the market. The fuel consumption is very limited when it reaches the correct reaction and that confirm fully the Andreev theory on the autothermia. For two years I am studying the process and only a few months ago I figured out how it really works . This is because our scientific knowledge is wrong and our mind does not provide solutions which we consider impossible. Well, the air that surrounds us can really burn and the reaction takes place each time. Obviously in the reaction also interacts nitrogen as the active gas and not as inert gas such as we are accustomed to consider getting high temperatures.
I can say with absolute certainty that this reaction was the cause of the cases occurred in the past related to human combustion .
Il processo e' una reazione a catena ma per funzionare ci sono delle variabili da rispettare, la piu' importante e' la temperatura e la seconda il catalizzatore usato.
Come combustibile ho ho usato pellet di legno ma e' possibile usare qualsiasi combustibile e/o olio vegetale presente sul mercato. Il consumo del combustibile e' veramente limitato se viene raggiunta la reazione corretta e questo conferma pienamente la teoria di Andreev sull'autothermia. Sono due anni che sto studiando il processo e solamente da pochi mesi ho capito come esso funzioni realmente. Questo perche' la nostra preparazione scientifica e' sbagliata e la nostra mente non contempla soluzioni che consideriamo impossibili. Ebbene l'aria che ci circonda puo' veramente bruciare e la reazione avviene ogni volta. Ovviamente nella reazione interagisce anche l'azoto come gas attivo e non come gas inerte come siamo abituati a considerarlo ottenendo alte temperature.
Posso asserire con assoluta certezza che questa reazione e' stata la causa scatenante dei casi avvenuti in passato relativi alla combustione umana.Last edited by tutanka; 11-09-2013, 11:29 AM.
Hello,
maybe there is re-discovery...
keep in mind:
FLOX flammeless burning
http://en.wikipedia.org/wiki/FLOX less information than in german version of wikipedia pages
http://de.wikipedia.org/wiki/FLOX-Verfahren german only
keep in mind, dont fool with:
holzvergasung / wood gasification ... not only suitable for wood
Hello,Originally posted by MrRonsen View PostHello,
keep in mind:
Absolutely not, Flox is an flameless tecnology!! Here we are talking of chemical plasma.. of course flame is every plasma but only oxygen interact with the fuel.. this technology instead is able to burn not only oxygen but also nitrogen. Here we are in presence of an high calorific bluish flame..Last edited by tutanka; 11-11-2013, 12:35 PM.
From the january 2014 the new air plasma technology is utilized on some pellet stoves. This technology save more pellet and decrease a lot the CO and NOx present into the exaust gas, an 13Kw stove that normally consume at max power 3.3Kg/h with new plasma burner consume 700gr/hour increasing a lot the thermal efficency.
