Building a window motor
  • #61
    May Have found it
    07-20-2015, 12:39 PM
    John_Bedini
    Silver Member
    • #62
      John, your post I had to delete to insert the others in sequence
      Today, 02:54 PM #0
      John_Bedini
      Super Moderator Join DateJul 2012LocationCoeur'D Alene IdahoPosts280
      • #63
        There is additional info on the use of shorted coils in transformers here:
        See the section "Secret 2 Switchable Inductance" located about 60% down the page, which gives some experiments and data.
        Off to try some tests, as this very much depends on phasing of the coils.
        • #64
          I was working with machine shops in my area and they all wasted the materials I supplied and wanted complete drawings of the final product. I have been working on all of the sg energizers with hand tools. Latest zero force motor. not working yet. Tesla switch, rpx and alum batteries. It is hard to replicate in the swamp. I have learned a lot and will not give up. I have hope when I get up in the morning and continue on the path. Happiness and Joy Jeff
          • #65
            You got in!
            • #66
              Thanks Aaron
              • #67
                I am in the process of building a window motor. I have some questions.
                Is there a picture of a jig for winding the coils so the shaft will go through?
                Can I use an Iron core for the rotor?
                Can I use a compound neo magnet configuration on the iron rotor?
                Thanks for your help Jeff Joseph
                1. Make provisions first for the rotor shaft insersion.
                2. Look,the window motor is essentially an Air-core motor. having a iron frame (if that is what you are asking) for a rotor that holds the magnets should not be an issue but its is preferred to be of a non-magnateic/non-conductive materials, although JB used aluminium cylinder for the Magnet -rotors.
                3.No. it has to be N-S-N-S all the way.
                Best Regards,
