I got the Small Window Motor from r-charge with the circuit assembled - I just soldered the four wires on and put the magnets together. Anyway, when I power it on, the motor spins for a moment (makes a thummmpp sounds) then stays locked in one place. The magnets are very hard to turn so obviously part of the circuit is working, I'm guessing just not the "on/off" part. Thinking it was a defective component, I actually ordered new components (with the exception of the circuit board) and desoldered the old ones, soldered on the new ones. I connect it back up - same issue. I'll attached some video showing it happening.
Any advice you can provide would be appreciated. I'm quite new to electronics though I've read the SG Beginners manual a couple of times, and the issue still eludes me.
Thanks very much
AJ
Thanks very much
AJ
