Mikey,
seems to charge with 2 channels of 14 awg as good as others machines with 7 with the 20 awg. I never completed my 8 strand coil (7 #20's, 1 #23), I only had 6 strands worth of 20 awg wire, then stole one for the trigger of my current 2 channel machine. I rewound coils on my little 3 channel machine with #20 power instead of #23 and changed it to attraction mode and this new one (based on your beast) kicks the pants off of it for car batteries. I think with the bigger wire I could go to 150-200' though and do better. We'll see. I have other things I want to try first, like adding a fwbr in gen mode like Pat is using. Aln
The SG Radiant Oscillator
i might have to try this... ive thought of doing it before, but i only have 40w of solar panels at the moment,,
mike i just used a radioshack 12v transformer and another heavier duty one from an old battery charger that wasnt working anymore(big wire as power winding), it would be interesting to see how it would act with multiple tranny coil, as it stands im just using them do rejuvenate and recharge primary battery for testing, it rips them up pretty fast considering amp draw, i would compare it to sg in gen mode if i had to but havent studied it that closely as far as measuring COP or anything
id love to hear how yours turns out
http://www.overunity.com/13393/desul...121489/image// - this is the schematic i used, i ended up using 120-12v transformer for coil
have you seen the re-emf charging circuits mikey? they seem to fit into what your talking about here kinda, and will work off of solar too, ive got one recharging my primary bedini battery thats hooked into a 24v power supply,
Mikey, Keep at it, and thanks for openness. Finally got some better resistors and using your beast circuit with a wheel, still tuning it, and desulfating batteries. Aln
Hi Mikey
Great posts like your style and all the info. Can you give details on your Alum conversion and the type of battery you are converting.
Thanks again.
Thanks for sharing that Mikey. Very encouraging results and testimonial! Thanks again.
The image you found appears to be from DVD #2 - Free Energy Generation. Here is the DVD preview where you can see a few of the machines JB has built.Originally posted by BroMikeyHi Erik
Maybe this one
[ATTACH=CONFIG]2772[/ATTACH]
was I wrong? Oops no black sand
Good to see you hanging out once in a while
No the DVD is one of the first I think Bearden and John Did. I don't know maybe in the teens.
JB has those acrylic wheels standing upright with belts hooked to gear reduction. It is a Muller motor and of course John has been making the Hendershot baskets and many other experiments. This guy has done them all. I think 18?
Hey Erik I want to keep using the impulse coils to pick up extra joules. What about a pancake coil? I mean how could I get enough wraps to make any real power? Last time I did the impulse coil experiment you did me right on an approx sizing that did more than fill a penlight battery.
My SSSG has a 5" dia 6" tall 7 pound coil in it. What-da-ya-say?
Put the cake on bottom?
Mikey
Yes, John Bedini has built the Hendershot device and understands how to make it work. I have no plans to ever build one. I am not aware of any Mueller style motors that John has displayed.
Are you familiar with the Mueller design? The coil and magnet arrangement are designed to minimized the lenz effect. I don't see how this could be done in the image you found with a single coil.
I have not done any experiments with a pancake coil. My suggestion with the coil you have would be to build a rotored version of an SG. Things happen differently when you have rotating magnetic fields that you will never understand working only with a solid state machine. For the size coil you have, maybe something in the 36" or 48" range. The larger you build your wheel, the more mechanical advantage you get at the shaft output. Add an appropriately size generator and load and it won't cost you any additional on the input.
Erik
Originally posted by BroMikeyJohn Bedini shows a Muller motor in "Energy from the vacuum" calls it a monopole turns the page to the bike wheel for beginners.
Mikey
Mikey,
Your reference is fairly vague. Are you referring to a DVD in the EFTV series (There are over 30)? or is this a reference to the EFTV book?
Regards,
Erik
Thanks, Ok
Anyway... I'm asking nonsense as a LED is enough to test the 555
I think I will use my time making ABHA coils, other pulser circuits and SSG's, as I still need to improve my radiant gathering before I can think of a Dump.
Dominus, if it's your circuit you can post it. If it's someone else's and you don't have permission you can't post it.Originally posted by Dominus View PostHi
I built Bedini´s cap dump from a coil-based radiant charger. Can I publish the circuit here?
Ok - It´s not working. The cap is charging but I have to dump it manually shorting A1 and A2 at the Triac.
How can I check where´s something wrong? I have no oscilloscope. The circuit is on a proto-board.
I haven´t even figured out A1 and A2 at the Triac but have already tried it reversing those 2
(It looks different on graphics I found on the internet)
What can I do?
***Beautiful blue sparks!!!
Jihn K.
Literally cool!Originally posted by T-1000 View PostIf you would like to see what it is on your table, there is simple circuit to try out (thanks to GeoFusion in OU forum)
2013 lighting 1kW using round core - YouTube
Kapanadze Cousin - DALLY FREE ENERGY
It is utilizing flyback transformer spikes back in primary coil and running it on resonance.
Cheers!
Hi
What can I do?
If you would like to see what it is on your table, there is simple circuit to try out (thanks to GeoFusion in OU forum)Originally posted by Dominus View Post"Cold electricity secrets" video from P. Lindemann really gave me some good insights about radiant energy and how to obtain it (what I haven´t done yet haha)
Cheers!
"Cold electricity secrets" video from P. Lindemann really gave me some good insights about radiant energy and how to obtain it (what I haven“t done yet haha)
