Hi all,
After building several successful lead/alum cells from old 12V gel cell batteries and testing my alum/water mix... I decided to try to make my first alum battery using a new Napa GS 12 volt (8 Ah) motorcycle battery.
I mixed the alum with warm distilled water in a blender to a nice constancy, "just a bit slippery between the fingers" , so I think it is good. I let the battery sit for about an hour before I applied the first charge, to ensure that the cells were evenly saturated. Looking back....I decided to charge the battery up on my SG energizer for its first charge, so I think the plates may not have been formed correctly.
I dont seem to be getting the final open circuit voltage to hold above 10.75 VDC. The battery takes a charge to about 13.99 volts, then drops off to 10.75 volts when the charger is removed. I tested the capacity with at load at C10 (1.2 amps) and the voltage just drops off, dramatically within 30 minutes.
Any help would be appreciated, thank you
as a Lead-Acid Battery....
