Hi all,
Found some videos on youtube which lead me to this site about creating an crystal battery using a copper tube (plumbing connection), magnesium core (meant to be 99.5% pure), with the 3 part mix of alum (food grade), epsom salt, potassium chloride (meant to be fairly pure but again not too sure on the purity level) and borax grind and packed between the copper and the magnesium. With a galvanized screw drilled into the magnesium core for the positive connector.
Have created a few cells so far, and each time when testing I get an voltage output of around 1.3 volts how ever when i switch it to amps uA the display will not show anything value over 0.
Just to ensure that I'm testing correctly have been using a 9 volt battery to compare against.
Is there something that requires to be adjusted in this format that I might be overlooking? Any help would be appreciated.
Also has anyone found that using electrical tape hindering their batteries voltage? I've created a cell as a test case using tape to keep the magnesium core and the copper away from each other in the event that there might of been an internal short.
just needed that baseline to get me started!
