Monopole Magnets
    S pole SSG motor
    Hi, I had an mistake to put magnets as S pole rotor.
    I have pasted them with glue and can not take them out anymore.
    Can anyone tell me how I should modify the circuite of SSG for S pole motor?
    Regards,
    KJP
      KJP, just wire the coils up backwards.
        Hi, John
        Thanks for your comment.
        When wire the coils up backwards, both power coil and trigger coil, right?
        or just power coil OK?
        I wonder if S pole SSG and N pole SSG is the same effect?
        N pole SSG motor is the better? If so I need to make an another rotor again.
        Thank you for your advice.
        KJP
          KJP,
          Yes, both power and trigger. I've never experimented with south poles out. John Bedini says to put them north pole out so that's what I do.
            Thanks, John
            It sounds like that JB says to make N pole out, that means there are some meanings to do so. I wonder if someone has tried to make a S pole SSG motor?
            I will think about buying a new rotor to re-build it.
            Thank you.
            Regards,
            KJP from ***AN
              Thanks John, I shall get me some of those. I was just being a cheapskate and using what I had floating around. The postage costs the same as the magnets.
              P.S. I reckon theres gotta be about as many Aussies here as there are yanks
                HI,
                Just let me clarify again.
                For S pole SSG, can I use the coil's opposite side?
                Because one side of a coil is N pole, and the another side is S pole, right?
                That means I can put the coil on the another side up for S pole SSG motor?
                KJP
                  KJP, yes you can just flip the coil too.
                    Hello all, I am gathering parts for a build. really trying to build it exactly as plans state... having trouble sourcing magnets... and wondering about tolerances. i have found locally a 1 x 2 x .5 ceramic, and want to know if this would work, and if so, how must my clearance between the coil change, father? tighter? or maybe i really need 1 x 2 x 3/8. thank you.
                      Hey John K,
                      Would these magnets work from Princess Auto Part # 8159063 1,000 to 1,200 gaus 2 pcs for $2.49
                      John
                        Originally posted by [email protected] View Post
                        Hey John K,
                        John
                        John, what size are they? Can you post a link?
                          John K
                          Here is the link.
                          2 pc Ceramic Magnetic Blocks | Princess Auto
                          John
                            Confuse about finding the North pole of my magnets...
                            Common sense is telling me the North pole of my magnet should attract the south part of my compass needle. Is it so?
                            I am asking because we know that magnets align themself N-S N-S N-S and so on. But I read somewhere that all our compass are wrong. Since the N on the compass needle point to the earth North pole, so in reality in order to follow the N-S-N-S alignment, the ''N'' on the compass needle should in reality be a ''S''.
                            Or is it our earth North pole that is in reality the south pole.....AAAaarrgghhhh!!!!
                              go to wikipedia..or
                              Shopwiki has thousands of results in Magnetic pole tester to choose from, find the best now!
                                I love to answer Fundamental question: well it does'nt really matter if it is S-pole or N-pole the term Monopole implies to either of these two , used as Single Pole (so Monopole) why John Choose to use N-pole consitently in all his writings, post, Patents, website ect. carries a deeper
                                Scalar -Electromagnetic base, well essestiall J.B has it experimentally verified about the Asymmetrical property of N-Pole camparrred to it Electric Counterpart.
