I made a 5 coil machine and so far it runs very well but I would have hoped for even better results
because I do not see a non linear improvement of the charging.
I will for sure not have a perfect tuning of all the parts but I am close.
I would like some advice on further improvements.
I mean I can add 5 more coils and more transistors but that is obvious.
I would like some tuning tips and any comment for improvement is welcome.
Will start to do some performance testing today.
The specs of the machine:
MDF rotor with 20 magnet slots for the superpole magnets the rotor weighs 1.6 kilo and is
covered with glassfiber and epoxy resign to prevent magnets flying off.
The bearings are ceramic bearings made for rolerskates.
the coils are made of r60 rods and 130 feet (40 meter) of 0.3 mm (#28 wire) 24 strand twisted together. every coil is around 1 kilo and resistance of around 0.6 ohms
It wants to run at about 1500 rpm using about 1.2 Amps input
Every coil is powered by two transistors (MJL21194) wich are matched. one diode 1n4007 is going from the two colectors to the high voltage bus and every transistor set has one neon.
the base of all transistors have a 22 ohm resistor and they go to a 500 ohm potmeter.
One coil has a trigger winding for all coils
I have a film of the machine here: new 5coil bedini monopole - YouTube
