Hi All --
Short story is my Bedini SG Machine is now running. Long story is how did I make it work. First lets start with
what John Bedini always said on all his videos and at the conferences. "Build the machine as I say to do it. Do not
make any changes." John Bedini also quote's Nikola Tesla by saying what he said "For those Skilled in the Art" you
can do whatever you want to do but make sure you know what your doing. I knew all along that my coil was going
to put out a stronger magnetic field due to the eight 16 gauge wires at 144 foot in length. By the way I am using
my 18 gauge trigger wire and not the 23 gauge trigger wire. My coil has both. The transistors do not get even warm
and they feel as if there is no power at all applied to them. Below are some voltage and current measurements
I made before and after running the SG Machine for 30 minutes.
Primary Battery start voltage was at 12.52 volts.
Charge Battery start voltage was at 12.48 volts.
Battery voltage after 30 minutes of running the SG Machine.
Primary Battery end voltage was at 12.38 volts.
Charge Battery end voltage was at 12.64 volts.
Current measurements while running Primary side - 0.34 amps.
Current measurements while running Charge side - 0.32 amps.
Now to get into what made the wheel start to run. First I added Neodymium Iron Boron 100 pound
pull magnets to the wheel on top of the number 8 ceramic magnets 2 at a time up till 8 where place on
the wheel. This is what over come the strong magnetic field the coil was putting out. Then the wheel
starting running on its own and from the looks of it it might be going slightly over 300 RPM.
-- James
-- James
Originally posted by James McDonald
