I finally finished building my 8 transistor SG kit and am having some troubles getting it to run. Wanted to see if anybody had any ideas on what I might have wrong. Here are some of the specs:
Both batteries are new lead-acid 8ah motorcycle batteries. The Primary battery is charged to 13.4v and the Charging battery is charged to 11.4v.
There are 19 magnets connected to the outer rim of an aluminum bike wheel that is about 23" diameter.
The gap between magnets and the coil is about 1/4".
I am also using the 12ohm 10W resistor on the trigger coil. (Currently I just have 1 Power Coil and the Trigger Coil connected) - set up to run in Attraction Mode.
I think I followed the instructions and what has been posted here, but may have missed something.
Going to try to attach a pic and a wiring diagram to show better what I put together. I did not get into the wiring of the SG board as it is the one I purchased.
Thanks for any help!
Randy -
Randy -
so I only have my phone to take pics with and for some reason it is having trouble focusing.
