Early Test Results 8-coiler
This first test was intended to be preliminary.
Purpose, to simply get it up and running and take a look around at it.
It runs on one transistor.
It runs for a while then rolls to a stop.
The ne2 bulb lights up when the charge side is disconnected.
There is accompanying audio as this happens.
It puts a charge to the charge battery.
RPM my first guess is around 100.
26 inch wheel presently with 31 magnets. ( This will be adjusted probably downwards to 24 in the next test ).
12vdc 7aH gel cells, not brand new.
If a piezo buzzer such as Radio Shack 273-0059 is connected across one of he coils, there is
output sufficient to activate the buzzer. However as the test continued, this changed,
and the buzzer itself was not up to volume. My explanation for this is REMF buildup.
Also, the buzzer emitted a sound similar to static towards the end of the test.
Other things being equal, this test is counted as 'successful'.
- Coye
- Coye
