Bedini TUV test "Highly Modified School Girl Motor"
  • Bedini TUV test "Highly Modified School Girl Motor"
    A quote from the link:
    DATE : OCTOBER 13, 2000
    BATTERY TEST SEQUENCE:
    One lead acid gel-cell (12 volts, 450 milliamps) is being utilized as the primary source fully charged at 12.5 volts.
    Three (3) lead acid gel-cell batteries (12 volt, 450 milliamps) strapped in parallel are being used as the charge destination. The batteries are discharged to 10 volts for the test purposes.
    Test #1 starts at 10:45 AM utilizing primary battery fully charged at 12.5 volts charging three (3) destination batteries paralleled. The destination batteries reach a charge capacity of 14 volts at 11:20 AM.
    The destination batteries are then discharged to 10 volts under working load to prepare for Test #2.
    Test #2 starts at 11:25 AM utilizing primary battery measured at 11.5 volts. Charging three (3) destination batteries paralleled. The destination batteries reach a charge capacity of 14 volts at 12:50 PM.
    The destination batteries are then discharged to 10 volts under working load to prepare for Test #3.
    Test #3 starts at 1:00 PM utilizing primary battery measured at 10.5 volts. Charging three (3) destination batteries paralleled. The destination batteries reach a charge capacity of 14 volts at 1:40 PM.
    The destination batteries are then discharged to 10 volts under working load to prepare for Test #4.
    Test #4 starts at 2:05 PM utilizing primary battery measured at 9.5 volts. Charging three (3) destination batteries paralleled. The destination batteries reach a charge capacity of 13 volts at 2:40 PM. The primary battery is now discharged to 9 volts under working load and unable to further run the Bedini motor generator.
    TOTAL BATTERIES CHARGED:
    12 lead acid gel-cell batteries (12 volts, 450 milliamps each). This ratio is a 12 to 1 charging factor. The motor operation (work) being performed as this was done is not included as an additional factor in this test.
    "The chart above is the TUV test of the Highly Modified School Girl Motor dual battery system using standard Radio Shack Batteries off the shelf, never charging the batteries out of their packages. What was the purpose of the Monopole Motor posted on KeelyNet, in answer to that question it was to explain the technology of the Potential Charging of lead acid batteries and how this is done with a Back EMF, or Electrostatic energy. As simple as the School Girl Motor was it opened a gateway into the understanding of how to transform many of these electromagnetic pulses into real useable power for lead acid batteries, and many other type cells. (...)"
    Gary Bedini
    "... the Highly Modified School Girl Motor dual battery system using standard Radio Shack Batteries off the shelf, never charging the batteries out of their packages."(...)
    So, as i understand, if a Bedini Monopole Energizer with capacitor discharge (and perhaps "inverted circuits"...) is properly tuned, it is capable to charge non "conditioned" batteries with a COP of about 12 ?
    Has anyone here been capable to replicate this effect (COP more than 1 with new batteries non conditioned) ?
    If so, what is "the secret" to properly tune this apparatus? is it the timing of the capacitor discharge ?the tuning of the resistance of the base transistor related to the capacitance of the capacitor ? the capacitance of the capacitor related to the Ah capacity of the charging secondary batteries?
    If John Bedini could help us to replicate this "Highly Modified School Girl Motor" , it would be a great advancement for the communauty ...
      Hi Max,
      You may be interested in this link here http://www.energyscienceforum.com/be...3.html#post188
        all the info is out there. John is not going to spoon feed anyone. its all in the patents. put the machines together in a unique way. everyone can buildone for himself. you have to read his Free energy Generation book, then build the machines. you really want to get into his stuff. buy the cjeka files DVD from The Tom Bearden Website it has most of his lab notes and most of his experiments.
          Hy Tom,
          I don't ask to be spoon fed (i 've read Free Energy generation many times,i've got the cjeka files DVD, and all Bedini DVD...), i just see contradictions between what rick is saying for years (battery is half of the system), the SSG first experiment who consist of conditioning the batteries to negative energy,in order to see how the battery behave with this different kind of energy, and the quote of Gary Bedini about the TUV test :
          ..."The chart above is the TUV test of the Highly Modified School Girl Motor dual battery system using standard Radio Shack Batteries off the shelf, never charging the batteries out of their packages." ...
          You, Tom, do you've ever seen a COP more than 1 with new batteries, in your Bedini radiant capacitive discharge experiment ? if yes, it can help me to see that my apparatus is not good tuned without making 20 or 30 cycles between another tuning ... (sorry for my english)
          I never seen a testimony of one who replicated the solid state version of the "Free energy Generation" book with COP>1, do you ? ( i don't say it's not possible, but it seems harder than it seems in the book...even if all infos is here...)
          It seems that a lot of us have missed someting, in the book and the DVD, but what?
          Thanks for your envolvment and your sharing since many years (John Bedini, Ren, Tom C , John Koorn, Min2oly, and all others...)
          Sam
            Originally posted by Ren View Post
            Hi Max,
              Monopole Help
              To All,
              Here, let me start this way, First of all the kits Rick has manufactured are just variations of my work (Changed), I do not know why things were changed but they were. I have never recommended any magnets except what I used in my models. In the past Rick and I have had many dis-agreements over what would work and what would not work. And now your experiencing It. I'm just going by what my lab models are, and believe me Rick has had plenty of time to study the machines and ask questions, but he did not, so here we are 30 years later. And I just got tired of talking to people that agree and then do what they want, thinking they know better. As I said when someone is given an opertunity to study differnt machines in the lab and copy everything, they should and that is all i'm going to say about it.
              Ren is right it is not as easy as it looks and most people do not have the time that I had to work everything out. The Monopole energizer can be made four different ways. One, just a monopole no recovery, Two, Capacitive dis-charge, three, Diodes to the recovery battery, fourth that I have never discussed but I must show it in a video which I'm going to do as soon as I can get things finished at work. Aaron and I have worked real hard to give you a place on this new board so we can sort out all the problems with the Monopoles first, then we will move on to the other energizers. The people who have made them work never return to help the others.
              Start with the basic circuit, one coil and one recovery battery do not exceed 120Ma of current (Primary) as the current is not important with the monopole, just the spike. The poles around the wheel should be kept to a minimum in the beginning until you gain an understanding of what is charging the recovery battery, as it is not current. When you change the form of energy you now have different perimeters to deal with and it may not be in the text. You must put your thinking cap on with this type of energy as it is not the same in how it works with things.
              John Bedini
              John Bedini
                To All,
                John Bedini
                I like the sound of this. Every time something new comes out from you I cant help but wonder just how many aces are up your sleeve that we have yet to learn about (Im pretty sure we have a life time of catching up to do!.) Something that I have wanted to build for sometime now has been a scalar north rotor, based on this schematic, found on your Tesla page.
                Im glad to see a milliHenry reading (1.3) on the second additional inductor, however I assume this is selected based on an ideal size master coil (x10 I take to mean as 10 full circuits, extra inductor and bridge/cap arrangement for each circuit.) I wondered if I may ask a question or two on the master/main coil? I am reminded of another device by a different artist who had a very similar arrangement, a second inductor of the correct inductance (in relation to the "master inductor") coming off the collector of the transistor. His device utilized a diode plug, but if that extra inductor wasnt correctly proportioned to the original inductor the energy cycling through the diode plug was minimal. Get that inductance right and your load at the diode bridge came to life.
                Would an 11 stranded coil of AWG 18 @ 150ft per length be suitable, or did you have a different size in mind here? And is this the litz configuration? I have a 16 pole rotor sitting on my bench that Id love to rebuild, and try the scalar arrangement with this circuit. As far as i am aware I have yet to see anyone build it.
                Ren
                  Just for inspiration.
                  I searched the net and could not find the video so I uploaded it myself here:
                  MVC 502V
                  It is unlisted, link only can view.
                  This energizer has a cameo appearance in EFTV DVD 2, but I find no real stats other than what John B. is posting on this forum.
                    Patrick,
                    Should we take this moment to congratulate you on your 100th youtube video, or does that last one not count because it's part of EFTV2?
                      Originally posted by MaxCaviar View Post
                      Hy Tom,
                      Sam
                      Sam,
                      yes, you will begin to see increases in your batteries from the FIRST charge cycle. I want to tell you to build it exaclty like the vanilla SG, I dont know what you are running. please post a picture with some circuit info.
                        Hi all I didn't know about this Forum!!!! Is your forum John Bedini??
                        I saw a link in energenx chanel in youtube.
                        I have always wandered what was the modifications on the SSG of the TUV tests, since it says that it where off the sheff batteries.
                        best to all!!
                          Hi all, I have made several variations of the version #1 monople and do speak up when I know the facts. I have helped others quite a bit. However I am smart enough to listen more than talk because I am very new to this arena. I will let the moderators do their part first. If someone wants my opinion I will be glad to give it but only if I know it to be factual. I do not want others rerunning the same mistakes I have made if possible. When it comes to mechanical know how and high end machining I am one of the best.....when it comes to electrical enginerring I stink!....I have never really studied it until now.
                          Since 1967 we have had a teaching tool and die facility. To this day we still teach and inspire others to follow the skilled trades. We have been very successful and I love to teach.
                          Today I just finished a 7 lead coil with #18 cu and charging L-16 batteries right now. I will post pictures and and details later. Thank you John for breaking the Ice on the #26 coil wire going to the #18 wire. Now I am not afraid to jump the boundaries and experiment.
                          Bud
                            Bud
                            Bud, if that was true this forum would not exist!
                              John Bedini
                              Hey John,
                              I have scoured this forum for that forth method to build the Monopole energizer or the video referenced. I'm hoping you are getting close to a release date of that video. I appreciate your work and have been inspired to build a couple versions of the above. My efforts of your generous contributions have not gone unrewarded. Do as you say and one will see things as you do! The references you make above are all related to recovery, so I'm guessing a variation of the recovery or different "funnel" for the radiant. As the SS SSG is not a Monopole, I'm guessing that you are not talking a version of that. Fun to guess. You're such a curiosity generator. Got mine going anyway. Thanks again for what you do.
                              Randy
                              Imagination can take you to places of new posibilities. Without it, you go where others tell you as you know no difference.
