Primary battery discharge. Why?
  • #46
    Thanks Mickey and Denis !!
    Happy new year !!
    • #47
      Merci my French friend.
      • #48
        Hi
        La reference du produit alun utilise est CAS 16828-11-8. C'est le sulfate d'aluminium hydrate: Al2(SO4)314H2O
        En France le prix de ce produit est de 5,1€ au kilogramme.
        regard.
        • #49
          Hi
          la reference du produit alun utilise est CAS 16828-11-8. C'est le sulfate d'aluminium hydrate: Al2(SO4)314H2O
          regard
          • #50
            Aluminium Sulphate
            Originally posted by intactsaphir View Post
            alun
            • #51
              Salut Denis
              j'ai achete 2kg de sulfate d'aluminium a 5,1€ kg. En France 6-7 euros de port.
              • #52
                What is the difference between standard mode
                and forced charging mode
                • #53
                  Hello Intactsaphir ,
                  I have not Atoute answers your questions, but I 'll do my best .
                  First, there are not advise to use Neodyn magnets. They are too powerful and they can saturate your reel. ie that sites have separate pulses ta coil would not temp to demagnitiser before the next magnet passes .
                  2) I can not comment on the capacitor with discharge ,
                  3) against I could tell you that the effect " electret " is less influenced by the value of the capacitor and a lot more construction and choice of materials. Peter suggested the L -type " camera flash "
                  4) in all cases the primary and secondary circuits can be connected in parallel . It's easier when the coils are connected directly to the battery charge . In case it y ' capacitors some synchronization is necessary.
                  I hope this is clear, I do not usually write are in french . I live in English for too many years .
                  Good luck , do not hesitate to ask more questions . I no longer use my wheel I go to something else at the moment.
                  NoFEAR
