Originally posted by totoalas
I've tried using a cap pulser with relay to dump into the source by disconnecting the source battery from the run side during the dump via a relay. This was just an experiment, but it did work technically. My run battery stayed at very close to the same voltage for a couple of hours. But after a couple of hours the battery was really warm. I noticed the next day that this battery no longer had great capacity. I had to cycle it a few times to get it to come back. So this tells me that rapidly charging and discharging a battery at the same time is a nogo. Capacitors on the other hand would not mind this at all. I was even thinking about trying some of those hybrid capacitors that have lithium ion chemicals. They charge fast like a cap, but discharge slowly like a battery.
Thoughts?
Chris
You actually don't want the cap to dump down to the battery voltage. Because then you have to use up more energy to fill it up to the dump voltage again. The large current pulse that is sent to the charge battery when the cap dumps is sufficient to get the battery to charge.
