suggestions for efficiency and/or advancement of the bedini motor
  • suggestions for efficiency and/or advancement of the bedini motor
    I'm new here, but has anyone thoght of magnetically levitating the rotor in a horizontal plane? would this present any advantage? Also I built a circuit off the internet (can't remember where) that seems to collect energy from the environment. With this circuit grounded and using a coffee can for an antenna, I measured almost 1/2 a volt. Could this circuit be an energy source for the bedini motor? From what I understand, the pulse or trigger coil takes only milliamps to energize. If so this would indeed be free energy.
    1- the only advantage would be less friction with no bearings, there are other problems isolating it horisontally. a vertical arrangement with magnetic bearings is much easier.
    2- post the cicruit please, voltage (potential) and current are 2 different things. even 200 volts wont do much good at 0 amps, you may be able to run a small oscillator circuit.
      Above is the URL to the circuit. By the way, I also hale from the Pacific Northwest in Oregon. I understand that one can "stack" these circuits to produce either more voltage or more amperage, but I haven't tried that.
        Here is a stacked circuit.
