Hello,
i have built the SG8 kit... is ready and running
here my SG8-kit in action...
what is the suggested typical primary amp draw with a SG8-Kit?
- 1,6 Amps drawing
- using the 10watt 12 ohm trigger
- attraction mode..
- everything keeps cool...
- 22inch wheel, 24 mags,
- 205 RPM at input of 1.6 Amps by 12.0-12.3 V
I think the primary amp draw is too high...
should i make the distance between Coil and Magnet wider..
so that induced trigger current will come down..
or should i keep the coil close as possible and add a potentionmeter into the trigger wire?
We want drive attraction mode.
But the core of the coil is stronlgy attractive to the magnets itself, already without powering coil.
So keep the coil more millimeters away
until the magnetic lock isnt there anymore/or less strong.?
And the trigger does still trigger..
then the powered coil will do the attraction...
going in which direction ?
- 1,6 Amps drawing
- attraction mode..
